Go Back   Honda Civic Forum > Honda Civics by Generation > 1st - 5th Gen Honda Civic
1st - 5th Gen Honda Civic As these Honda Civics get older and older they become harder to find in great condition and less popular to modify. By no means does this make them less of a contender on the track or car audio competition. Don't forget the roots of what made import tuning what it has become today.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 12-23-2007   #1 (permalink)
88CivicDad
New Member
88CivicDad is an unknown quantity at this point
Stuck Brake Light Switch
Like the username implies, it's an '88 Civic.
Got a sticking brake light switch (brake lights stay ON when car is off). I have not yet crawled under the dash to check it out. Anybody know if this is a common problem, and what's the likely cause? Will I likely need to clean it, or just replace it?
Thanks.
Jack
88CivicDad is offline   Reply With Quote
Sponsored Links
Old 12-23-2007   #2 (permalink)
CraigW
Platinum Member
CraigW's Avatar
CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light
Re: Stuck Brake Light Switch
Not sure the switch could be cleaned ?? Make sure the plunger is in and releasing when pedal pushed. Unplug switch connector as a quick diagnosis (and to save battery, or pull fuse)
CraigW is offline   Reply With Quote
Old 12-23-2007   #3 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
arent those switches cheap anyway? could just have gotten worn out.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 12-24-2007   #4 (permalink)
DieMaster
Senior Member
DieMaster's Avatar
DieMaster is a glorious beacon of light DieMaster is a glorious beacon of light DieMaster is a glorious beacon of light DieMaster is a glorious beacon of light DieMaster is a glorious beacon of light DieMaster is a glorious beacon of light DieMaster is a glorious beacon of light
i ran into the same problem on my 91 all 4th gen civics 88-91 have this problem and i'm not sure if other gens have it too.
the problem is not the switch ( it could be but unlikly) the problem i had was the plastic disk that pushes the switch cracked and fell out. so theres now a hole in the pedal where that plastic thing was. i just went to home depot and got a bolt and locknut. dont remimber the size though. installed it in the hole and never had a problem since.
DieMaster is offline   Reply With Quote
Old 12-27-2007   #5 (permalink)
88CivicDad
New Member
Quote:
Originally Posted by CraigW View Post
...Unplug switch connector as a quick diagnosis (and to save battery, or pull fuse)
Doh! Why didn't I think of that?
Quote:
I just didn't want to do it and find out that wasn't the problem.
Now, that may have saved me some time and money. That's the first thing I'll check, thanks.
Jack
Old 01-12-2008   #6 (permalink)
88CivicDad
New Member
And that is why I joined. Nice job, it's as if you were looking at the car. I even found bits of the disk on the floorboard.
Thanks.
Jack
Old 01-30-2008   #7 (permalink)
civicninitwo
New Member
civicninitwo's Avatar
civicninitwo will become famous soon enough civicninitwo will become famous soon enough
This is a little tip to help those with this same problem. You can use one of the plastic door panel clips (holds the door panel to the door) Best of all it's something that you already own if you are having this problem.FREE!
civicninitwo is offline   Reply With Quote
Old 02-10-2008   #8 (permalink)
88CivicDad
New Member
Quote:
Funny, that's exactly what I used, only I bought it rather than taking it from the door. I had to use a washer behind it.
Jack
Old 02-17-2008   #9 (permalink)
MultiCRX
New Member
MultiCRX is an unknown quantity at this point
Hey Jack,
I was gonna' help ya' w/that one, but they were all over you before I could get there. It IS a common problem.....and what is so funny is I used a push pin too.... Usually, unless you see the lights on...the battery might run down or get a little sluggish... happened to my wife's CRX.
Pupfriend,
uh, MultiCRX
MultiCRX is offline   Reply With Quote
Old 07-03-2009   #10 (permalink)
traveler928
New Member
traveler928 is an unknown quantity at this point
Wow that's really good info my 97 Civic is having the same problem. Can you explain a little further how you made the fix using the door clip? I know what the switch looks like but I can't picture the broken piece that may be causing the problem.
Thanks!
traveler928 is offline   Reply With Quote
Old 07-03-2009   #11 (permalink)
CraigW
Platinum Member
CraigW's Avatar
It will push into a hole in the brake pedal arm the disc at the top allows the contact between the 2 to be plastic to plastic & not metal to plastic.
Old 07-03-2009   #12 (permalink)
traveler928
New Member
That worked!!!
You guys just saved me over $50 and a ton of hassle.
Thanks for saving the day.
Old 07-03-2009   #13 (permalink)
DeX
Canadian, Eh!
DeX's Avatar
DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all
I don't get it. Are you saying the (P) parking brake light on the dash is stuck on? Why would you bother with the brake pedal arm?
__________________
7th Generation Member Against Street Racing Number 43
www.em2ab.com
Fully integrated carputer with W-Fi, GPS, 2000 songs/music videos, and weather
7 inch Xenarc 700TSV VGA in dash touchscreen
Compustar 2 way paging alarm/starter system
35% tint excluding windshield
D.I.Y. Blacked Out Headlights
D.I.Y. Debadge
D.I.Y. Remote Trunk Release
D.I.Y. Trunk Air Shocks (Scouting Parts)
Air Ride Suspension Setup (Awaiting Parts)
DeX is offline   Reply With Quote
Old 07-04-2009   #14 (permalink)
CraigW
Platinum Member
CraigW's Avatar
The brake lights in rear were staying on.
When the plastic bit comes out the switch does not get pushed back in to open circuit.
Old 09-23-2009   #15 (permalink)
oldskoolSi
New Member
oldskoolSi is an unknown quantity at this point
I had same problem, but now after replacing the plastic clip into the brake pedal, when ever i push on brakes my dash lights up.... and when the headlights go on - my rear brake lights go on... WTF? i cleaned battery terminals & checked fuses. maybe a ground some where? it was all working fine (87 civic hatch Si) till the plastic disc disintergrated. Any help or ideas are appreciated - Thanks
oldskoolSi is offline   Reply With Quote
Tags
1991 , 1995 , 97 , brake , break , change , civic , fix , honda , light , lights , lx , replace , stuck , switch
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Need Underhood Fuse Box Diagram
VIN Numbers: You should know where your civic was quality built!
1995 Civic DX rough idle what causes it and how to fix
1997 Civic Coupe Tinting
best gas milage setup
95 Ex Coupe
My 95 Honda Civic EX Coupe
d17a2 d16 transmission
specs/info for the 1983 Civic 1500 S
ED6 D15B Engine Questions
Site Supporters
aluminum radiator
Honda car spoilers
