Go Back   Honda Civic Forum > Honda Civics by Generation > 1st - 5th Gen Honda Civic
1st - 5th Gen Honda Civic As these Honda Civics get older and older they become harder to find in great condition and less popular to modify. By no means does this make them less of a contender on the track or car audio competition. Don't forget the roots of what made import tuning what it has become today.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 08-22-2007   #1 (permalink)
ridinlowhonda
New Member
ridinlowhonda's Avatar
ridinlowhonda is an unknown quantity at this point
Send a message via AIM to ridinlowhonda Send a message via Yahoo to ridinlowhonda
Question d15 what it worth
is it worth keeping a d15 and turboing it, what can i get out of it hp wise??? To remove this ad, register today for free or log in if already registered!
ridinlowhonda is offline   Reply With Quote
Sponsored Links
Old 08-24-2007   #2 (permalink)
MMKennedy
Member
MMKennedy's Avatar
MMKennedy will become famous soon enough
Re: d15 what it worth
I'd say no, but it's all personal preference right? Some people don't like swapping, other's see it as essential. Assuming you got a 25-30hp turbo, you'd see maybe 120-130 max? Without any other modifications. For the amount of money and trouble it'd be worth, I'd still say no. I'm waiting till I can afford to do a swap, even with just a swap you'd probably be pushing more power than the D15 with the turbo...
MMKennedy is offline   Reply With Quote
Old 02-22-2008   #3 (permalink)
G-reazie
New Member
G-reazie's Avatar
G-reazie is an unknown quantity at this point
Send a message via AIM to G-reazie
nah not true at all...first question is the d15 vtec or is it a d15b7? ...if its the vtec model its already at like 115 - 125 horse power.. and u cant jus slap the turbo on it...it would require building it, low comp pistons, new fuel injectors for higher flow.. with a good stage 1 clutch and a few other mods u can get a good 250 hp out of that d15 ... good luck id love to see a write up on this
G-reazie is offline   Reply With Quote
Old 03-04-2008   #4 (permalink)
vega66
New Member
vega66 is an unknown quantity at this point
Quote:
Ehh iv seen stock setup turbos running 8-9psi with stock internals. Buddy of mine is running a similar setup and its been running for about 2yrs now. But either a swap or if you want to stay with the d-series (aka cheap route) you should find yourself a d16a6. Probably close to the best d-series engine you can find. Pretty sure people on here already know that the A6 block has the steel gurdel(sp?) as far as the rest of the d-series engines they have the aluminum ones. Just my 2cents
vega66 is offline   Reply With Quote
Old 03-04-2008   #5 (permalink)
02BLKCIVIC
Official Rattlesnake Hunter
02BLKCIVIC's Avatar
02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of
D15 Vtec for the win!!!!
__________________
02BLKCIVIC is offline   Reply With Quote
Old 03-09-2008   #6 (permalink)
90 hatchman84
New Member
90 hatchman84 is an unknown quantity at this point
hey what d15 do u have. I have a 90 hatchback with a d15b2. I'm really interesed how this works for because im thinking of doing a mpfi swap on mine so i can chip it out and put on a vtec head.Well hope to hear how this works out for u.
90 hatchman84 is offline   Reply With Quote
Old 05-04-2009   #7 (permalink)
ECivic19
New Member
ECivic19 is an unknown quantity at this point
I have a D15b7, what can i do to change it to VTEC?a mini me??
ECivic19 is offline   Reply With Quote
Tags
a6 , d15 , d15b7 , head , honda , swap , turbo , worth
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Need Underhood Fuse Box Diagram
VIN Numbers: You should know where your civic was quality built!
1995 Civic DX rough idle what causes it and how to fix
1997 Civic Coupe Tinting
best gas milage setup
95 Ex Coupe
My 95 Honda Civic EX Coupe
d17a2 d16 transmission
specs/info for the 1983 Civic 1500 S
ED6 D15B Engine Questions
Site Supporters
aluminum radiator
Honda car spoilers
