Go Back   Honda Civic Forum > Honda Civics by Generation > 1st - 5th Gen Honda Civic
1st - 5th Gen Honda Civic As these Honda Civics get older and older they become harder to find in great condition and less popular to modify. By no means does this make them less of a contender on the track or car audio competition. Don't forget the roots of what made import tuning what it has become today.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-14-2007   #1 (permalink)
aspencer80
New Member
aspencer80 is an unknown quantity at this point
'91 Civic randomly fails to start - Fuel pump problem?
My good old 91 Civic has begun to not start more and more often now. It happened once a couple years ago but was fine for a year or so afterwards. Now about once or twice every two weeks it will fail to start for about 5 - 10 minutes. The starter cranks the engine over but theres no ignition. I've replaced the spark plugs, wires, and distributer all within the last year and the fuel filter within the past two years. Sometimes it happens when the car is cold, sometimes it happens after I've been driving for a while but turned the engine off to run into the store and returns some DVDs (like it did today).
When it doesnt work, I just try it again every minute or so. After a while it will just start up as if nothing wrong happened.
It never happens in a quite enough spot to hear if the fuel pump engages or not (I understand it gives off a slight hum if its working properly), and I dont know how else to tell if fuel is reaching the engine.
Anyways. Does this sound like a fuel pump problem like Im thinking? And if you think its a fuel pump problem, is there anything I can do about it? I understand the fuel pump is located in the gas tank
Thanks for any help
aspencer80 is offline   Reply With Quote
Sponsored Links
Old 07-15-2007   #2 (permalink)
AmbulanceMonkee
AmbulanceMonkee's Avatar
AmbulanceMonkee should not be questioned AmbulanceMonkee should not be questioned AmbulanceMonkee should not be questioned AmbulanceMonkee should not be questioned AmbulanceMonkee should not be questioned AmbulanceMonkee should not be questioned AmbulanceMonkee should not be questioned AmbulanceMonkee should not be questioned AmbulanceMonkee should not be questioned AmbulanceMonkee should not be questioned AmbulanceMonkee should not be questioned
Send a message via AIM to AmbulanceMonkee
Re: '91 Civic randomly fails to start - Fuel pump problem?
more likely the relay for the fuel pump. i think on the 01-05's it's behind the glove compartment. i have no idea where it would be on a 91. i'd search around for info on the relay, before i go into pulling the fuel pump itself, especially if it's fine once it does start.
__________________
Life is hard. It's harder when you're stupid.
Search, and learn.
Quote:
Originally Posted by modoman View Post
the same curiosity some people have with the minds of serial killers, i have with ricers.
Quote:
Originally Posted by DeX View Post
You don't have a sport car.
"There are more than 550 million firearms now in circulation, one for every 12 people on the planet. The only question, is how can we arm the other 11."
newest pics of my car.
AmbulanceMonkee is offline   Reply With Quote
Old 07-15-2007   #3 (permalink)
DeX
Canadian, Eh!
DeX's Avatar
DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all
With the doors shut it should be quiet enough to hear the pump unless you're in some construction zone. Shut the doors, turn the key 2 clicks and listen for a 1-2 second hum. If that is the problem, you'll have to pull the tank to get at it but like the Monkee says, check the relay first.
__________________
7th Generation Member Against Street Racing Number 43
www.em2ab.com
Fully integrated carputer with W-Fi, GPS, 2000 songs/music videos, and weather
7 inch Xenarc 700TSV VGA in dash touchscreen
Compustar 2 way paging alarm/starter system
35% tint excluding windshield
D.I.Y. Blacked Out Headlights
D.I.Y. Debadge
D.I.Y. Remote Trunk Release
D.I.Y. Trunk Air Shocks (Scouting Parts)
Air Ride Suspension Setup (Awaiting Parts)
DeX is offline   Reply With Quote
Old 07-15-2007   #4 (permalink)
AmbulanceMonkee
I'm pretty sure it's a relay. my dad had a truck with a similar problem. to get it to start, you had to turn the key on and off about 10 times, and the fuel pump would finally start. then, sometimes when you shut the vehicle off, the fuel pump would keep running. he'd have to pop the hood, and whack, the relay a couple times with a screwdriver or something. i definitely wouldn't invest in a fuel pump till you replace the relay. and yeah, you should be able to hear it when it comes on.
__________________
Search, and learn.
Old 07-27-2009   #5 (permalink)
Tacoma_trd01
New Member
Tacoma_trd01 is an unknown quantity at this point
My 90 Civ Hatch does the same thing! I turn the key an the fuel pump won't come on, an thats when its really hot outside, on cooler days the car starts just fine!? The fuel relay is "if your sittin in your drivers seat, you have those fuses under the steering column, its to the left of that, kinda right behind the hood release, if you lay down an look under, you should see it, at least tahts where it is on my 90, shouldn't have changed in one years time, but let me know if you replace the relay an it works fine, or I'll let you know, cause thats my next thing to do
Tacoma_trd01 is offline   Reply With Quote
Old 07-28-2009   #6 (permalink)
DeX
Canadian, Eh!
DeX's Avatar
I'm pretty sure the guy didn't wait 2 years to check his relay.
__________________
www.em2ab.com
D.I.Y. Debadge
Tags
91 , 97 , civic , civiv , drivers , fuel , gas , honda , located , pump , pumps , relay , remove , replace , seat , tank
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Need Underhood Fuse Box Diagram
VIN Numbers: You should know where your civic was quality built!
1995 Civic DX rough idle what causes it and how to fix
1997 Civic Coupe Tinting
best gas milage setup
95 Ex Coupe
My 95 Honda Civic EX Coupe
d17a2 d16 transmission
specs/info for the 1983 Civic 1500 S
ED6 D15B Engine Questions
Site Supporters
aluminum radiator
Honda car spoilers
