Go Back   Honda Civic Forum > Honda Civics by Generation > 1st - 5th Gen Honda Civic
1st - 5th Gen Honda Civic As these Honda Civics get older and older they become harder to find in great condition and less popular to modify. By no means does this make them less of a contender on the track or car audio competition. Don't forget the roots of what made import tuning what it has become today.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 05-19-2007   #1 (permalink)
sfong33
New Member
sfong33 is an unknown quantity at this point
Question 1988 Civic Alternator Removal - Help!
I have managed to get the alternator on my 1988 Civic off of the alternator bracket, but am having problems actually getting the alternator out of the car. Space is very tight . It looks like it can only be removed from the bottom. Does the axle have to come off (I hope not) or is it just a matter of removing the alternator bracket? Any help is greatly appreciated. To remove this ad, register today for free or log in if already registered!
sfong33 is offline   Reply With Quote
Sponsored Links
Old 05-19-2007   #2 (permalink)
oopsracing19
New Member
oopsracing19 is an unknown quantity at this point
Re: 1988 Civic Alternator Removal - Help!
alright man this is goin to bee kinda difficult to do but take off the alt bracket and take the alternator around the back of the engine between the fire wall and the engine. u may have to take off a coolant hose but from there if u can you should be able to move hoses/lines/wires around to get it out if that dont work post it by 3pm central (nebraska) time today and let me know if it works. ok? good luck
__________________
GIT-R-DUN
oopsracing19 is offline   Reply With Quote
Old 05-19-2007   #3 (permalink)
oopsracing19
New Member
also what is the engine size?
__________________
GIT-R-DUN
Old 05-19-2007   #4 (permalink)
sfong33
New Member
GIT-R-DUN:
I am blocked off at the rear by the braking system components. Can't see the space that you are referring to that I can route the alternator through.
It is a 1.5 liter motor if that helps. Thanks for your replies.
Old 05-19-2007   #5 (permalink)
CivicHatch9one
7th gen old timer.
CivicHatch9one's Avatar
CivicHatch9one should not be questioned CivicHatch9one should not be questioned CivicHatch9one should not be questioned CivicHatch9one should not be questioned CivicHatch9one should not be questioned CivicHatch9one should not be questioned CivicHatch9one should not be questioned CivicHatch9one should not be questioned CivicHatch9one should not be questioned CivicHatch9one should not be questioned CivicHatch9one should not be questioned
Send a message via AIM to CivicHatch9one
i used to bring it to the left side of the motor and pull it up from the top. or remove the axle. good luck... its easier without the stock airbox for the first method...
__________________
CivicHatch9one is offline   Reply With Quote
Old 05-19-2007   #6 (permalink)
oopsracing19
New Member
you are going to have to route it down lower i do agree that it is easier without the stock air intake. but you should when u get it behind the engine slide right under the intake
__________________
GIT-R-DUN
Old 05-19-2007   #7 (permalink)
oopsracing19
New Member
civichatch9one has the same idea i do cuz it will come out the left (passenger) side if pulled from the top
__________________
GIT-R-DUN
Old 05-19-2007   #8 (permalink)
oopsracing19
New Member
what is the sub model? None, 1500 dx, dx, lx, se, 4wd?
__________________
GIT-R-DUN
Old 05-19-2007   #9 (permalink)
CivicHatch9one
7th gen old timer.
Quote:
yup! (pete btw) and yea thats the way i did it after the first axle removal. its so much easier. but i might have to take out my motor to put my new one in. due to b18. i havnt touched my hatch in a while
__________________
Old 05-20-2007   #10 (permalink)
sfong33
New Member
This is a 1.5 DX Wagon with A/C (don't think having A/C makes a difference). I am away for the weekend, but will try sliding it over to the passenger side of the engine bay. Just glad to hear that I don't have to remove the axle (not something I feel comfortable doing). Thanks to all who have replied so far. FWIW, I made a few phone calls and the dealer quoted me 1.8 hours of labor plus the cost of the alternator, which came out to almost $500. Even the local mechanic said he would charge $390. I'm sure they can remove it in way less time than the "book hours" quote. Thank goodness for these forums. You guys are the best!
Old 06-27-2007   #11 (permalink)
sfong33
New Member
Update: managed to get it out up through the middle of the engine along the firewall. Took a LOT longer to do the swap than I anticipated. Some of the bolts were a real pain to get off (having the proper tools makes the job so much easier. I was using a cheap socket/wrench set from Target and just couldn't get enough torque to loosen 2 of the bolts). Also, because I cut the alternator belt off (it was worn anyway, but the main reason was that I couldn't get the adjuster bolt loose), I had to also remove the A/C belt. This involved more research and borrowing a proper wrench set. The remanufactured unit seems to be working great. Now, it seems that I might need new axles. Crap.
Old 06-27-2007   #12 (permalink)
oopsracing19
New Member
the axles arent going to be as hard as the alt. i will tell you that
__________________
GIT-R-DUN
Old 07-02-2007   #13 (permalink)
CivicHatch9one
7th gen old timer.
true story
__________________
Tags
1988 , alternator , civic
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Need Underhood Fuse Box Diagram
VIN Numbers: You should know where your civic was quality built!
1995 Civic DX rough idle what causes it and how to fix
1997 Civic Coupe Tinting
best gas milage setup
95 Ex Coupe
My 95 Honda Civic EX Coupe
d17a2 d16 transmission
specs/info for the 1983 Civic 1500 S
ED6 D15B Engine Questions
Site Supporters
aluminum radiator
Honda car spoilers
