Go Back   Honda Civic Forum > Honda Civics by Generation > 1st - 5th Gen Honda Civic
1st - 5th Gen Honda Civic As these Honda Civics get older and older they become harder to find in great condition and less popular to modify. By no means does this make them less of a contender on the track or car audio competition. Don't forget the roots of what made import tuning what it has become today.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 04-23-2007   #1 (permalink)
oopsracing19
New Member
oopsracing19 is an unknown quantity at this point
1991 crx
what would make my crx idle vary from 1200rpm to 2000 rpm? i sounds like i am just tapping the gas and letting off. but there are times that it idles just fine. ive tried vac lines but it still does it. To remove this ad, register today for free or log in if already registered!
oopsracing19 is offline   Reply With Quote
Sponsored Links
Old 04-24-2007   #2 (permalink)
PowerWheels86
Member
PowerWheels86's Avatar
PowerWheels86 is an unknown quantity at this point
Send a message via AIM to PowerWheels86
Re: 1991 crx
the throttle body... i think.. my car occasionally has that problem... i read somewhere it has to do with the throttle body on our older cars... i'll comeback later... but let me check...
PowerWheels86 is offline   Reply With Quote
Old 04-30-2007   #3 (permalink)
elusive_da
New Member
elusive_da is an unknown quantity at this point
Re: 1991 crx
ok next time it does it pop ur hood and look at the intake manifold ull see a little round thing on the left side on the back, it looks like a roll of quarters it has 2 collent lines running in and out of the bottom of it.... and 1 plug on the left end, tap on it with a screw driver kinda hard.... it should fix it.... tear it off and clean it with break cleaner, use about 2 cans and then let it dry out for a few hours.... or just get a new 1.... i belive its called a cold idel control senser.... but im not sure of the name.... good luck
elusive_da is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Need Underhood Fuse Box Diagram
VIN Numbers: You should know where your civic was quality built!
1995 Civic DX rough idle what causes it and how to fix
1997 Civic Coupe Tinting
best gas milage setup
95 Ex Coupe
My 95 Honda Civic EX Coupe
d17a2 d16 transmission
specs/info for the 1983 Civic 1500 S
ED6 D15B Engine Questions
Site Supporters
aluminum radiator
Honda car spoilers
