Go Back   Honda Civic Forum > Honda Civics by Generation > 1st - 5th Gen Honda Civic
1st - 5th Gen Honda Civic As these Honda Civics get older and older they become harder to find in great condition and less popular to modify. By no means does this make them less of a contender on the track or car audio competition. Don't forget the roots of what made import tuning what it has become today.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 02-27-2007   #1 (permalink)
Kowalske
New Member
Kowalske is an unknown quantity at this point
92 Civic Shaky Steering
A couple of days ago, my 92 Civic started to 'shake' while I am driving at low speeds. If I take my hands off the wheel, I can see it wobble left and right very slightly. This goes away when I increase speed and drives completely fine once I am at higher speeds (30+). Will an alignment take care of this? What could have caused it to happen suddenly? To remove this ad, register today for free or log in if already registered!
Kowalske is offline   Reply With Quote
Sponsored Links
Old 02-27-2007   #2 (permalink)
zonk
Member
zonk's Avatar
zonk is on a distinguished road
Send a message via AIM to zonk Send a message via MSN to zonk Send a message via Yahoo to zonk Send a message via Skype™ to zonk
hmmm have you hit anything recently...ie curbs, road debris, stuff like that. also when was the last time you had it aligned.
__________________
92 civic dx hatch
zonk is offline   Reply With Quote
Old 02-27-2007   #3 (permalink)
Kowalske
New Member
I do not recall htting anything obvious. I have never taken this car in for an alignment...but this shaking started very suddenly.
Old 03-02-2007   #4 (permalink)
PowerWheels86
Member
PowerWheels86's Avatar
PowerWheels86 is an unknown quantity at this point
Send a message via AIM to PowerWheels86
more than likely it's the alignment... but sometime hitting a good size rock in the road can put bumps in your tires and could be the reason for the shaking at low speeds you feel the bumps more etc. check the tires and if not go in for the alignment better safe than sorry...
PowerWheels86 is offline   Reply With Quote
Old 03-03-2007   #5 (permalink)
zonk
Member
zonk's Avatar
^^^ agreed, an align,ment should e done like every 6-12 months depending ont he road type you drive on, in centex where i am at the roads have a lot of bumps in them causing me to need an alignment like every 6-8 months , back in north carolina where i am originally from it is required maybe once every year. i know your car sitting a while would put bumps in your tires also, i am battling that problem since my car sat for a year while i was away at war. id have an alignement done and the tires balanced and rotated just to see if this solves the problem, and then write back if the problem doesnt go away
__________________
92 civic dx hatch
Old 03-03-2007   #6 (permalink)
PowerWheels86
Member
well i do an alignment every time i buy new tires... and that's about every 6 months... hahaha i need a new suspension... it's running my tires thin... '86 honda's are hard to find performance springs and shocks for...
Old 04-30-2007   #7 (permalink)
elusive_da
New Member
elusive_da is an unknown quantity at this point
Re: 92 Civic Shaky Steering
or check ur lug nuts.... good luck
elusive_da is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Need Underhood Fuse Box Diagram
VIN Numbers: You should know where your civic was quality built!
1995 Civic DX rough idle what causes it and how to fix
1997 Civic Coupe Tinting
best gas milage setup
95 Ex Coupe
My 95 Honda Civic EX Coupe
d17a2 d16 transmission
specs/info for the 1983 Civic 1500 S
ED6 D15B Engine Questions
Site Supporters
aluminum radiator
Honda car spoilers
