How much oil is measured between low and full marks on 98 Civic dispstick?
Old 10-23-2016
prr
prr's Avatar
prr is an unknown quantity at this point
I'm finishing up my first Civic oil change. I can't find out the amount of oil that the distance between the full and low marks on the dipstick measure. I poured in 3.5 quarts; I changed the filter as well as drained the oil, so I know I didn't overfill. I'd just like to know immediately, when I go check the dipstick. My Sienna owners manual had the measurement, but I couldn't find it in the Civic 98 manual.
Does anyone know?
prr is offline
Old 10-23-2016
Re: How much oil is measured between low and full marks on 98 Civic dispstick?
99% of ALL cars on the road: one quart
ezone is offline
Old 10-23-2016
prr
prr's Avatar
My Sienna owners manual says the distance signifies 1.6 US quarts.
prr is offline
Old 10-23-2016
Benz engines, many were two quarts between marks.
Now oil dipsticks have become obsolete for some manufacturers.
ezone is offline
Old 10-23-2016
prr
prr's Avatar
If you were to see a Civic that had oil halfway between the two marks, you would add 8 ounces? Just to be on the safe side (knowing that I had already put in 3.5 quarts, when the total capacity including filter was 3.8), I put in about 6-8 ounces. Now that I look back, that was probably a tad too much, but I suppose the marks have a slight tolerance.
At least, I hope so.
One other issue (should have taken care of this before I added) was that it wasn't 100% clear where the oil was. I did two measurements and it seemed like it was halfway between.
The newer cars (at least the expensive ones) don't have dipsticks---they have a readout on the dashboard? The Sienna dipstick has been very tough to read, usually the Civic is pretty clear. I would love to have a dashboard display to remove all doubt.
prr is offline
Old 10-23-2016
Anywhere between the two marks is a safe area. You can let it go or dump in some dribbles as you see fit.
I used to see those engines come in seriously overfilled on a regular basis. 4.5 quarts, maybe 5 quarts. Still see 7th gens come in way overfilled.
"All oil changes get 5 quarts! (no matter if it needs it or not)"
ezone is offline
Old 10-24-2016
prr
prr's Avatar
After an 8 mile drive this morning, I stopped the car, waited a few mins and measured the oil. I'm not 100% sure, because the oil wasn't easy to see on the dispstick, but it was eitehr right at the full mark, or just under 1/5 inch above.
Unless I'm on dangerous ground (which I doubt at this point), I'll just let it stay there.
prr is offline
Old 10-24-2016
Prelude Owner
GolNat's Avatar
After an 8 mile drive this morning, I stopped the car, waited a few mins and measured the oil. I'm not 100% sure, because the oil wasn't easy to see on the dipstick, but it was right at the full mark, or just under 1/5 inch above.
I would let it sit longer then a few minutes.
Honda uses the metal dipsticks which I find a lot easier to read the the plastic ones.
GolNat is offline
Old 10-24-2016
When I do an oil change I don't have a few minutes extra. 10 seconds is pushing it.
Yeah the orange plastic sucks sometimes when trying to look at clean oil.
I have a few different old metal dipsticks saved as special tools just because of this.
ezone is offline
Old 04-28-2017
prr
prr's Avatar
Today, I had the unfortunate opportunity to find out approximately how much oil is between the low and full marks on my dipstick. With the oil right at the low mark, I poured in 26 ounces (measured with a 16 oz cup with 2 oz markers), and the oil level was just a hair under the full line. I won't top off until I see that i need more than that; I'll check it once more after a drive to operating temps, and a few mins rest.
But for now, I can safely estimate it at 7/8 (28/32) of a quart. So ezone was (nearly) right.
prr is offline
