civic does not start and fuel injector vavle leak
Rep Power: 0 civic does not start and fuel injector vavle leak
Hi,
my car does not start (cranks only) after I clean the fuel injector and intake manifold.
so I check the spark with tester and it is fine.
then I check the fuel pressue with tester and the pressure shoots to over 42 psi without starting (normal between 38 and 46 psi) and slowly drops to 10 psi. I install fuel injector (FI) with new o-ring and gasket and there is no leakage aroung them. the fuel pressure regulator is ok. I got one from junk yard and the test show the same.
I notice there is some gas inside TB and only way to leak the gas is the FI body vavle. I took all FI out and notice #2 and #3 are wet on the FI nozzle tip and use small syring to push air through and can see some fluid coming out from the nozzle tip.
I thought I clean it well and do not know if this can be fixed by more cleaning. the resistance is all the same at 12.6 ohms under room temp at night in north CA
K2Mediahouse
01-23-2016 04:52 PM
spotty
12-04-2015 11:14 PM
steve6
11-22-2015 08:18 PM
R Steele
10-22-2015 05:09 AM
