My car is shaking & i don't know why !!!
Rep Power: 0 My car is shaking & i don't know why !!!
Hi experts ,
I have a mysterious issue in my Honda Civic 2000 LX , the car start shaking from about 2 months ago and the muffler smoke is choppy then the check engine light popped up with a code P0420 so i changed the catalytic converter and the spark plugs and the wires of the plugs and the distributor cap and the whole throttle body with the IACV sensor because the RPM always low however none of these solutions worked , i fed up and i am thinking to sell this car , so if any body know what's going on here kindly help me
Thanks
Thanks
Dr Krieger of Modification
Re: My car is shaking & i don't know why !!!
If the shacking is because of the engine then you know it is because the engine is not running properly (obviously).
The engine needs
-air
-spark
-fuel
-ecu sensor data
The cat. going on you could be due to running rich.
-Have you changes the timing/timing belt recently?
-Have you performed any maintenance/modification or other services lately (last 6 months)?
The engine needs
-air
-spark
-fuel
-ecu sensor data
Rep Power: 0 Re: My car is shaking & i don't know why !!!
yeah recently i changed the timing belt and i am hearing squeaky noise coming from inside the engine is that might be the problem ??
Yes.
If the timing is just a bit off it will run but the air intake, exhaust output, fuel burn will all be out of sync. with your piston position during the detonation cycle.
Check your timing or re time it.
the mechanic told me that the engine is loosing compression and he has to change the whole pistons if i need to fix it and this gonna cost about 1000 $ & for sure this is too much for an old car like this but i was searching online for a solution i found some liquid called engine restorer in a silver can and many people posts some videos talking about this product and how amazing is that , but i am always don't believe that any liquid can fix a physical issue like low compression or leak or whatever , so what do you think ??
No need to replace an engine if that's the actual cause, it can be corrected fairly easily.
What were the results of that test? Where is the compression loss going?
Valves?
I wonder if I should buy stock in the company.
The following users liked this post:
CivicHybrid03 (07-04-2020)
Save your money.
First verify that the timing IS correct!
This guy could be taking you for a ride.
Go to another shop and have the timing checked.
If the timing is perfect and the new shop wants to work on internals then use the shop with the lessor price.
Did OP bend some valves during DIY timing belt job?
damahark
10-28-2015 08:11 AM
shriketheavatar
10-20-2015 08:31 PM
