'98 Civic DX shorting issue
Old 10-24-2015
Derdiedas's Avatar
Derdiedas is an unknown quantity at this point
Was driving my '98 DX when I smelled a faint electrical burning smell, then the car lost power. No lights, no crank. With battery leads connected, battery voltage is near 0 VDC. With battery leads disconnected, battery voltage begins climbing back up from near 0 VDC back up to 12 VDC. The faint burnt smell is in engine compartment even after 2 days. So, either battery can't support a load, or a big short is holding down the voltage? Any ideas fellas?
Derdiedas is offline
Old 10-24-2015
Re: '98 Civic DX shorting issue
Unbolt the alternator hot lead from the fusebox and recheck.
Wire will be either white or white/red.
If joy, then disconnect battery, reconnect lead at fusebox, then disconnect large wire from the alternator itself and retry.
ezone is offline
Old 10-24-2015
Derdiedas's Avatar
What are the odds?? A full battery failure (confirmed and replaced)...and a manual transmission failure at the same time? The manual 5 speed shifts into any gear with or without clutch with engine on, and nada, no tranny. The clutch pilot reservior fluid is full. It's manual...can't be any fuses. Any guesses?
Old 10-24-2015
Stock 99's Avatar
check your linkage from the shifter to the transmission...maybe you lost/broke a bolt or something like that.
Stock 99 is offline
Old 10-24-2015
Derdiedas's Avatar
Nope. Can visually see the linkage responding to the shifter at the back of transmission. Although I can shift into any gear without the clutch and no grinding and engine on, when I do the same thing with clutch being let out I do see a minor drop in RPMs, but no stall at all. Clutch or transmission?
Old 10-24-2015
A wasted clutch would explain "faint burnt smell is in engine compartment even after 2 days"
ezone is offline
SuperNova18
24
09-02-2019 10:46 PM
Uan
08-23-2015 03:03 AM
Zugor
08-21-2015 08:36 PM
2005seTO
08-18-2015 12:45 PM
Michael white
08-14-2015 03:38 PM
Quick Reply: '98 Civic DX shorting issue
