Can anyone tell me what this is and how to fix it?
Re: Can anyone tell me what this is and how to fix it?
Looks like you circled the sway bar (stabilizer bar). What's wrong with it?
Looks like you have a crapton of rust under there too.
I can't tell what broke in the pic.
If the half-circle steel bracket rotted through, you can buy that.
If it ripped the mounting pad out of the subframe, that's a bit trickier.
Ok that pic looks like it ripped the mounting pad out of the subframe.
Technically it would be needing a subframe (may be called a crossmember?), if what I see is correct.
but....If there's that much rust, the rest of the car may not be very structurally sound.
Maybe you can find someone to weld it, but there may be too much rust to do that.
Received 1,146 Likes
Rep Power: 485 Re: Can anyone tell me what this is and how to fix it?
Looks like too much rust, to me, as well. However, I'm not a certified welder, nor can I see it in person, so take our opinions with a grain of salt.
jpandjf
08-03-2015 05:02 PM
