Radiator Fan, ON @ 22 Minutes!
Old 10-15-2015
aztecaa's Avatar
aztecaa is an unknown quantity at this point
Question Radiator Fan, ON @ 22 Minutes!
Hey guys, question regarding my Fan.
I was sitting in traffic the other day for 2 hours in the heat and noticed that my car was over heating. So when I had a chance noticed the Fan was not on. I ordered a new one. Replaced it...Come to find out that the old one still worked...DUMB on my part for NOT testing it. Replaced it anyways...
I started the car and let it idle for at least 25 mins before the fan turned on and that was only for short time before it turned off.
So I changed the Fan Cooling switch that goes into the thermostat housing. I let it run again at idle and set my stop watch and it took 22 mins before it turned on and only for short time.
So my question is...what else could it be or is this normal. I had the radiator replaced 2 years ago and the cap. I replace the upper rad hose last year. I have 144,000 on the engine and run only synthetic oil. I think my lifters need to be adjusted, but other than that my car runs great.
Any help will do, Thanks...
aztecaa is offline
Old 10-16-2015
Super Moderator
Poopies's Avatar
Re: Radiator Fan, ON @ 22 Minutes!
Originally Posted by aztecaa
[COLOR="Navy"]is this normal
Is what normal? The car overheating?! The fan only turns on when the coolant reaches a certain temperature threshold, but that's long before an overheat situation. Is it possible that your thermostat isn't working properly? Is there enough coolant in the radiator and reservoir?
Also, what's with the blue font?
Poopies is offline
Old 10-28-2015
aztecaa's Avatar
The blue font helps me when going thru my posts
and I like it...Thanks for the help info on the coolant, just bought
some water wetter and put a little in to see if it helps. I hope it
was just from driving hard and then sitting in traffic for 2 hours,
that this happened but I probably need to change the thermostat...
aztecaa is offline
Old 10-28-2015
Mad Dog Tannen's Avatar
Water wetter won't do anything for you, unless you are racing. You need to get it to run right first.
Is it still overheating? the fan is supposed to kick on and off as the coolant temperature goes up and down. The best way to test is while idling parked. if the fans turn on and it's not overheating, then you are good to go.
Mad Dog Tannen is offline
Old 11-29-2015
aztecaa's Avatar
What is normal...Does it take over 20 mins NORMALLY while idleing before the Fan kicks on...That's all...
aztecaa is offline
Old 11-29-2015
That sounds about right. If it gets hot without the fans kicking on, then there is a problem. By hot, I mean the temp gauge on the dash gets hotter than normal. It should stay in the same place and the fans should just kick on. Also feel the hoses, is the bottom one much cooler?
Old 11-29-2015
It depends on a lot of stuff, and the fan is never operated by a time constraint.
If the heater is running it may remove enough heat from the cooling system to significantly delay or negate the need for the radiator fan to run. Same if there is a breeze blowing through the radiator, the fan may not be needed.
The rad fan only needs to turn on when the temperature of the coolant EXITING the bottom of radiator and entering the engine is sufficiently hot (200* ish F) to turn on the thermoswitch in the stat housing.
ezone is offline
The following users liked this post:
guest3939392 (06-01-2023)
Rob02Civic
09-16-2018 09:16 PM
Sarahwv2910
22
06-17-2015 12:35 PM
cukaracha
06-11-2015 08:44 AM
eorlando1
05-17-2015 11:16 AM
onelifetolive
Bolt-on Engine Performance
11-10-2001 10:58 AM
Quick Reply: Radiator Fan, ON @ 22 Minutes!
