98 civic, HELP!!
Old 07-14-2015
Dani1993's Avatar
Dani1993 is an unknown quantity at this point
98 civic, HELP!!
I'm looking for someone who knows a lot about Hondas. I have a 98 civic I'm having some intermittent issues with, has after market parts but they are simple modifications like the intake and exhaust. I've had several people look at it and no one seems to be able to find the issue. It is bogging and loosing power in every gear but neutral, and here recently the idle has started surging.. when you drive it hard it doesn't have an issue and when you accelerate it smoothes out. I've replaced throttle position sensor, air intake temperature sensor, upstream O2 sensor, rotor button, ignition coil, throttle cable, and alternator. At first it was only reading a air intake temp sensor code, replaced it and now it's reading misfire in any cylinder. Spark plugs and wires are all good. This is a 1.6L d16y8 vtec engine. Fuel filter is fine I have removed and checked it also. Any suggestions are greatly appreciated. Vehicle never cuts off and starts immediately every time.
Dani1993 is offline
Old 07-24-2015
Genyc07's Avatar
Genyc07 is an unknown quantity at this point
Re: 98 civic, HELP!!
Since nobody has ventured a guess I will. I bet their is an intermittent block in your exhaust consistent with a cat converter where the pieces inside have deteriorated over time. But really just I guess IDE have to drive it to be anymore certain. Good luck let us know
Genyc07 is offline
jonavin
73
10-04-2004 07:18 PM
locozoko
04-06-2002 09:00 PM
silvervtec01
11-04-2001 06:56 PM
locozoko
11-04-2001 05:45 PM
WeRkX
11-01-2001 10:33 PM
Quick Reply: 98 civic, HELP!!
