Sticky Gas Pedal
Old 06-01-2015
cukaracha's Avatar
cukaracha will become famous soon enough
Sticky Gas Pedal
Hey guys,
I noticed that my gas pedal feel "sticky" but not in a way that causes surges in acceleration. Rather, it feels physically sticky and has resistance when I step on the gas pedal, kinda like when a bicycle's V-brake cable is dirty, you feel it in the brakes levers. Put differently, stepping on my gas pedal almost feels like there are notches rather than being continuous.
Any ideas what might cause this and how to fix it?
Thanks!!
cukaracha is offline
Old 06-01-2015
RIPSAW's Avatar
RIPSAW has a spectacular aura aboutRIPSAW has a spectacular aura about
Re: Sticky Gas Pedal
Could be the cable if you have one. Remove it at throttle body to check. Know Toyota's get a little crude at the throttle butterfly. Safest way to fix is remove the large tube and maybe airfilter box. Hold open the throttle and use a rag sprayed with carb/throttle body cleaner to clean opening and butterfly. Get both sides carefully. Don't just spray. There are openings that lead places and if you wash the crud into them and it dries, it can stick throttle position sensors and stuff (the one on the Toyota truck I have had it stuck when I got it from that).
RIPSAW is offline
Old 06-04-2015
cukaracha's Avatar
I tried cleaning the cable and the metal spring reel thing but that didn't seem to work. I'll try cleaning out the throttle body and see how that goes.
SidCivic
09-12-2015 05:28 PM
mikebj23
07-28-2015 08:08 PM
wootah88
07-21-2015 10:22 AM
Trennytrent
07-10-2015 09:01 PM
ezone
HIDs and Retrofitting
07-04-2015 12:44 PM
Quick Reply: Sticky Gas Pedal
