97 Honda Civic HX -Check engine light (need advice on 4 Codes) - Honda Civic Forum
Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Generation Civic
6th Generation Civic In the years from 1996 to 2000 Honda released it's 6th Generation Civic. Chassis codes: EK9, EK4, EK3, EJ6, EJ8, EJ9, EM1
LinkBack Thread Tools Search this Thread
Old 03-23-2011   #1
fernando97honda is an unknown quantity at this point
I have a 97 Honda Civic HX with the check engine light on. I need to clear it by this friday for a smog check. The codes I got are P0303, P0304, P1300, P1399. Occasionaly when driving the check engine light blinks but clears back to a sold light when I release and press the gas pedal. The car drives perfectly with the check engine light on and the occasional check engine light blinking. The car accelorates fine, it basicly run very well but I don't understand why I can't clear the check engine light when I've already changes the spark plug wires, spark plugs and the cap and rotor. Can you help and tell me what I need repair to clear the check engine light?
Thanks in advance,
Fernando Gamboa
Last edited by fernando97honda; 03-23-2011 at 04:12 AM. Reason: need daily email notification.
fernando97honda is offline   Reply With Quote
Old 03-23-2011   #2
asianboy781 is a jewel in the rough asianboy781 is a jewel in the rough asianboy781 is a jewel in the rough asianboy781 is a jewel in the rough
Send a message via AIM to asianboy781
Re: 97 Honda Civic HX -Check engine light (need advice on 4 Codes)
Quote:
Thanks in advance,
Fernando Gamboa
reset the codes using a portable obd2 scanner tool if not avail
take out battery for about 5 min
neg terminal
asianboy781 is offline   Reply With Quote
Old 03-23-2011   #3
lazlong's Avatar
lazlong has much to be proud of lazlong has much to be proud of lazlong has much to be proud of lazlong has much to be proud of lazlong has much to be proud of lazlong has much to be proud of lazlong has much to be proud of lazlong has much to be proud of lazlong has much to be proud of lazlong has much to be proud of lazlong has much to be proud of
First, you may not pass on Friday even if you fix it today. You usually need at least 100 miles in all conditions to reset all the readiness codes.
For P1399 Honda has reported clogged EGR passages and valve clearance issues as being the cause(s) of this code.
Take the EGR off and clean it and the engine passages you can reach with carb cleaner. Then reset the ECU thru a scan tool or removing the neg battery cable. Drive it around a little bit then check for codes again. If no OBD codes- drive it a while to set readiness codes and then get it inspected. If it still has OBD codes- check valve clearance.
lazlong is offline   Reply With Quote
Old 03-23-2011   #4
Trance Addict
MelJ's Avatar
MelJ is a glorious beacon of light MelJ is a glorious beacon of light MelJ is a glorious beacon of light MelJ is a glorious beacon of light MelJ is a glorious beacon of light
MelJ87
Send a message via AIM to MelJ
Yeah. I'd try and actually take care of the problem, because like lazlong said, they're still stored in there for a while until the computer runs the checks over and over again to make sure the tests are okay.
__________________
2000 Civic Si- Short ram intake. Yeah. Rollin' in the mods, kid.
Brakes-These slow the car down!
Break-This is what twigs and sticks do!
Quote:
Originally Posted by lazlong
*Before any of ya say "WTF does VTEC have to do with a hard start?" I'll tell ya I got it straight from the manual and have no idea.
6th Gen Manual
Please PM me for broken links
MelJ is offline   Reply With Quote
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
2006 Civic Engine block crack KNOWN DEFECT Xuhme Mechanical Problems/Vehicle Issues and Fix-it Forum 3 04-21-2015 07:21 PM
00 honda civic lx overheating jessicakaybby Mechanical Problems/Vehicle Issues and Fix-it Forum 5 04-20-2015 12:11 PM
Hello from Oregon! CascadiaBlue Introduce Yourself! 11 04-18-2015 09:13 AM
2003 Hybrid with hesitation/ stuttering at low rpms/speed dooner24 Mechanical Problems/Vehicle Issues and Fix-it Forum 1 04-14-2015 07:51 PM
check engine cluster issues. please help bahena08 7th Generation Civic 2 04-11-2015 05:09 PM
Tags
96 , 97 , 98 , check , civic , codes , egine , engine , honda , hx , light , located , plug , problems , spark , switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
vBulletin Skin by ForumTemplates.com
All Content Copyright 2007 CivicForums.com
