Center console bulb replace DIY and others
Old 01-22-2010
davegu's Avatar
davegu is an unknown quantity at this point
Did a few searches, maybe answers are here. If so sorry same question/s being asked.
98 LX automatic with burned out center console bulb. Any DIY for replacement?
Also heater / AC control panel bulb/s out.
Doesn't look obvious to me as to how to replace these bulbs.
TIA --
Dave...
davegu is offline
Old 01-22-2010
civicpapi's Avatar
civicpapi is an unknown quantity at this point
Re: Center console bulb replace DIY and others
TIA --
Dave...
I have done the center console, you remove the rear portion first a few screws lift off, then remove the front section a few screws where the shift handle is that pulls off. Right under the indicator P R D etc there is a little wire with a bulb holder just pops out, tiny little bulb, might have to get it at the Honda dealer.
I have the same problem with the ac/heater bulb not sure about that one, or if it is even replaceable.
civicpapi is offline
Old 01-22-2010
davegu's Avatar
Thanks. I'll give what you suggested a try, although I don't recall seeing any visible screws in the center console. My daughter has the car now. I'll take a look when she brings it home.
davegu is offline
Old 01-22-2010
cb450sc's Avatar
cb450sc is an unknown quantity at this point
Look for the screws and bracket behind a cut out that just snaps out.
cb450sc is offline
Old 01-22-2010
civicpapi's Avatar
I have a coupe, but I believe the consoles are the same. Push the 2 front seat up and look at the sides the arm rest console you will see them. the front section has 2 screws towards the back 2 towards the front. Then lift the pieces off.
bsmiley
04-27-2015 01:27 PM
thesushiboy
04-12-2015 02:54 AM
Foom
12-06-2001 01:11 PM
2k2civic
12-02-2001 11:35 PM
NeoMagus
11-17-2001 07:29 AM
Quick Reply: Center console bulb replace DIY and others
