'99 civic emissions problems
Rep Power: 0 '99 civic emissions problems
I have a '99 civic auto with about 130000 mi and the check engine light came on. I took it to auto zone and the scanner said O2 sensor bank 1. I replaced the primary (upstream) sensor, but the light came on immediately after it was reset. I changed the secondary sensor (downstream), and the light came back on as soon as it was reset. It is still giving me the same code. Is it possible I got a bad sensor or should I be looking somewhere else for a problem? At times, the check engine light has been blinking which is usually a sign of the computer totally losing communication with some monitored part. Does anyone know the proper voltages and resistances I should be seeing across the O2 sensor and heater terminals? Any help is appreciated. Thanks.
Rep Power: 203 Re: '99 civic emissions problems
A blinking CEL indicates that the engine is misfiring severe enough to damage the catalytic converter (cat). You need to fix the problem before driving more to avoid the need to replace the expensive cat.
Start by taking the car to an auto parts store to have all the codes pulled again. Then post the codes in this thread.
Rep Power: 787 Re: '99 civic emissions problems
yeah blinking cel you shouldnt drive the car. are you sure you got the correct sensors? oem plug in type and did not mix the primary and secondary? if you replaced with proper sensors, the light should go off. make sure you have a good connection at the plug too.
I had the cel blinking like that ran the codes and it came up misfire cylinder 1 and cylinder 2.
Pulled the distributor housing off and saw a few drops of water. Cleaned those off, then sanded down the contact points and reinstalled. Also my air filter was a little wet so I dried it off with a hair dryer.
This is all because of the massive rain we got here in San Diego over the last week, I drove through some 1 ft deep flooded roads and thought flooring it would be fun in the water, all that did was splash tons of water up into my engine bay.
Try checking your ignition components next. Distibutor cap, rotor, plugs, wires, and spark plugs.
Xuhme
21
08-07-2023 03:40 PM
Civicchicky87
Idle Issues
04-22-2015 07:16 PM
dooner24
04-14-2015 07:51 PM
bahena08
04-11-2015 05:09 PM
