96 civic. No automatic transmission filter?
Old 01-29-2008
96beatercivic's Avatar
96beatercivic is an unknown quantity at this point
Why would honda not put any kind of filter (not even a magnet) on these cars? Just seems weird to me that the only way to really service one is to have it back flushed on a machine.
Mine is starting to down shift harshly at stops, and found out the only "screen" is deep in the transmission and I would have to remove the whole transmission to clean it.
96beatercivic is offline
Old 03-20-2008
TheJGB3's Avatar
TheJGB3 is an unknown quantity at this point
Re: 96 civic. No automatic transmission filter?
Honda trannys are "drain and fill" do not use a back flush machine. And yes there is a magnet - on the end of the drain plug. AND THE MOST IMPORTANT THING TO REMEMBER: USE ONLY HONDA ATF-Z1 OEM FLUID
TheJGB3 is offline
Old 03-20-2008
you can buy the HX civic cvt exterior fluid filter, but its prolly too late for that. do it after you get a new trans put in.
gearbox is offline
Old 03-24-2008
Justinsn95's Avatar
Justinsn95 is an unknown quantity at this point
Originally Posted by TheJGB3
Honda trannys are "drain and fill" do not use a back flush machine. And yes there is a magnet - on the end of the drain plug. AND THE MOST INPORTANT THING TO REMEMBER: USE ONLY HONDA ATF-Z1 OEM FLUID
hmm... i havean appointment at a local transmission service shot to get my fluid changed. now i am wondering if i can trust them to use the right kind. maybe ishould just go to autozone and get the right stuff and take it to them and tell them touse my stuff when they cange it? how do you guys change yours when you get it done? and how often does it need to be changed?
Justinsn95 is offline
Old 03-24-2008
well, only the honda dealer sells the right stuff. i usually change mine in the parking lot, every year or two.
gearbox is offline
Old 06-18-2012
midmocfp's Avatar
midmocfp is an unknown quantity at this point
most Car Quest stores carry it or can order it, but not much cheaper in general - if you want to try and save a buck a liter, give em a call
midmocfp is offline
RIPSAW
11-06-2015 04:36 AM
97-DX-Lover
06-14-2015 06:07 PM
vtecbrah
05-31-2015 01:24 PM
cruisers10
05-12-2015 10:46 PM
Flipg123
05-08-2015 01:15 PM
Quick Reply: 96 civic. No automatic transmission filter?
