$500 to replace o2 sensor??? - Honda Civic Forum
6th Generation Civic In the years from 1996 to 2000 Honda released it's 6th Generation Civic. Chassis codes: EK9, EK4, EK3, EJ6, EJ8, EJ9, EM1
LinkBack Thread Tools Search this Thread
Old 01-16-2007   #1
jester458 is an unknown quantity at this point
so my friend took her 98 civic dx to the dealership cause she got a cel. they pulled the code and it was P0141 which is "O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)"
they said both of her o2 sensors need to be replaced, and it will cost a little over 500 dollars. ($210 and $185 for the 2 sensors, plus 2 hours of labor.) it sounds rediculous to me, but 2 questions come up.
do the o2 sensors even need to be replaced?
should it cost 500 bucks?
any help would be good, cause i know nothing about civics.
thanks a lot
jester458 is offline   Reply With Quote
Old 01-16-2007   #2
hondacivicluv's Avatar
hondacivicluv is an unknown quantity at this point
I would replace the one it called for...DO IT YOUR SELF... if it still calls a code then replace the other... I have a 97 civic ex and my O2 sensor (in the header) was like 95 dollars from advance auto parts... my other O2 (in the cat) has never called a code! $500 is way too much!!! the dealer just want your money so they will tell you to replace both of the sensors!!! you wont get as good gas mileage with the O2 not working...... or you can not worry about it in till its time to get your inspection sticker!!! thats what we are doing with our 98 accord!!!!
Hope this helped!!!!
hondacivicluv is offline   Reply With Quote
Old 01-16-2007   #3
if i were to replace the sensors myself...
are they easily accessible?
do i have to F* with the wiring (any splicing or whatever)?
and do i need to replace both of them even though the code (from my understanding) is only describing a problem in one of the sensors?
Old 01-17-2007   #4
i would just replace the one it calls for... theres one in the header and one is in the exhaust... just find out which one it needs... it sounds like the one in the exhaust... you can go to any advance auto parts store or auto zone (if you have one) and they can read the code and tell you... the O2 sensor comes with a plug on the end so theres no cutting the wires... unless you get a universal O2 sensor then you will have to cut the wires... but i would get the O2 sensor with the factory plug... the one in the header is very easy... if you have the factory manifold then i think you have to take the cover off (you can still see the wires) and the O2 sensor screws out... the one in the exhaust is alittle harder... its in the catalytic converter... i'm not sure if you will have take the bolts loose or just have someone pull on the exhaust not sure havent had to replace that one.....
Old 01-18-2007   #5
alright, thanks a lot for the help. at least now i have some idea of what to expect, and where to start. Thanks again.
p.s. WRX's for life!
Old 01-19-2007   #6
1civicpower's Avatar
1civicpower is an unknown quantity at this point
they r so easy to do i would be crazy if i pay 500 even for both the only hard part at least for me was getting the old one out it felt like it was welded or something other than that pretty easy to do
1civicpower is offline   Reply With Quote
Old 01-19-2007   #7
sql_civic's Avatar
I have your car and have replaced both of these sensors using a 19mm wrench, I believe (eh could be 17mm). Spray some liquid wrench on it and let it soak. When your done reset the ECU by disconnecting the battery for 10 seconds or so.
From the Helms Factory Manual:
P0141 (65)
Secondary Heated Oxygen Sensor Heater Circuit Malfunction (Sensor 2)
Probable Causes:
1 - Open or short in Secondary HO25 (Sensor2) heater circuit
2 - ECM/PCM
It's probably not the ECU (computer).
The secondary HO2 sensor is just below your cat in the lower front part of the engine. Here's a piture of where it is (part #9):
sql_civic is offline   Reply With Quote
Old 04-29-2009   #8
rk92yj is an unknown quantity at this point
Re: $500 to replace o2 sensor???
Im sorry I am a noobie to civics, if this a stupid question. I bought my daughter a 99 dx with an aftermamarket exhaust and the lower O2 sensor was reading code. I purchased the advance oem O2 sensor and it is extrremely short, maybe a foot. Is there an after market pigtail connector to purchase to marry the two together. If there is, can someone give some info. I did a search and did not find the answer.
rk92yj is offline   Reply With Quote
Old 04-29-2009   #9
Mavrick272's Avatar
Mavrick272 is an unknown quantity at this point
Yes, they make O2 sensor extender cables
I got mine from this place:
http://www.casperselectronics.com/st...x.php?cPath=14
Click on Honda on the left. They come in 12", 24" and 36"
They plug right in, piece of cake, no splicing wire or any of that crap (which could screw up the voltage and cause the CEL to remain on, I am told)
There are no stupid questions, only stupid previous owners
hope this helps!
Mavrick272 is offline   Reply With Quote
Old 04-29-2009   #10
Mavrick272's Avatar
I don't think you'll need one though. If it's a DX the cat converter should be in the manifold like on my LX. The connection point should be really close...
Old 04-29-2009   #11
Images: 178
make sure you bought the right one. most cars have two sensors, one upstream closer to the engine (primary), and one downstream inside the cat converter (secondary). if you got the bosch oem type sensors from advance, they should plug right in exactly like the factory sensor and wiring.
gearbox is offline   Reply With Quote
Old 04-05-2010   #12
805er is an unknown quantity at this point
2000 civic lx i have question. The o2 senser on the exaust manifol which wire is the signal return {COLOR} thanks.
805er is offline   Reply With Quote
Old 04-26-2010   #13
Token21 is an unknown quantity at this point
hey i have a 97 honda civic ex coupe and is the A/F sensor the primary o2 sensor? i went to auto zone and it said i had an A/F senor 1 problem. any ideas? theres a probe for my intake i think and its not hooked up i tried hookn it to the intake but there isnt a hook up on the cold air intake
Token21 is offline   Reply With Quote
Old 04-26-2010   #14
Images: 178
a/f sensor is the primary yes. but i think your car uses a regular 02 sensor and not an a/f sensor. #5 is the primary sensor. the secondary is in the cat converter.
Old 05-18-2010   #15
guju4you is an unknown quantity at this point
I have Honda civic Hybrid and I got kind of same problem as everybody in here. I used code reader and it saws two codes. One is P0139 - sensor circuit slow response and other one is P1130. Do I need to replace all oxyzen sensors or just one? Anybody has any diagram that shows how to access these sensors? or anything that will make my life easier?
guju4you is offline   Reply With Quote
Old 05-18-2010   #16
Administrative Rice. WAT?!
Images: 39
xRiCeBoYx has much to be proud ofxRiCeBoYx has much to be proud ofxRiCeBoYx has much to be proud ofxRiCeBoYx has much to be proud ofxRiCeBoYx has much to be proud ofxRiCeBoYx has much to be proud ofxRiCeBoYx has much to be proud ofxRiCeBoYx has much to be proud ofxRiCeBoYx has much to be proud ofxRiCeBoYx has much to be proud ofxRiCeBoYx has much to be proud of
what year hybrid?
xRiCeBoYx is offline   Reply With Quote
Old 05-19-2010   #17
it's 2005 honda civic hybrid
Old 05-19-2010   #18
Images: 39
Should be able to reach the O2 sensors by jacking up the car. Looks like it should be about below the center console, in the center of the car.
Also, from what I can see, the sensors are sold as a (fairly pricey) kit. Majestic Honda has it for $337.28
http://www.hondaautomotiveparts.com/...PIPE+-+MUFFLER
Old 05-27-2010   #19
lazlong's Avatar
Had to replace o2 sensor 35K ago. Figuring I'd try it to see if it works before I spent $100 I took it out and knocked off all the crap on it with the wire wheel on my bench grinder. Haven't had a problem since. cost=free
*NOTE: I have no idea if this is legal in your state so I have no
liability if you do it illegally.
lazlong is offline   Reply With Quote
Old 06-01-2010   #20
asianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the rough
theres a tool that allow you to take out your o2 sensor on ur own,
they have it at any auto part store
i got mine for about 10 bucks
and bosch 02 sensor for 120
problem fix
after u change it just remove the neg terminal on ur battery for about 5 min so the ecu reset itself
then put ti back on and start your car.
no more cel light
this was the tool that i was talking about
http://www.autozone.com/autozone/cat...roductId=47738
asianboy781 is offline   Reply With Quote
Old 10-15-2010   #21
pprime1 is an unknown quantity at this point
I would like to thank all of you that posted answers to the o2 sensor question.
Just bought a '95 ex, 173,xxx, with the engine light on. Seller said that the Honda dealership could not remove the sensor without possibly cracking the manifold. Found the part for $65.00 locally, and bought a Lisle open groove socket for $15. The OD of the socket would not let me get close enough to the nut, because of the manifold. Called around; O'Reilly not only had one with 3 widths, but I could rent it for free for a day. Picked it up at 5, back by 6: engine light off. They also rent code checkers by the day, just have to leave the purchase price as a deposit.
Don't know if this is Kosher, but I added a 2 foot pipe over my wrench handle, making sure not to slip off-axis on the nut. Didn't need it to put the new one one with it.
Next project: rear wheel fender rust.
Thanks again!
pprime1 is offline   Reply With Quote
Old 11-21-2010   #22
gonzal12 is an unknown quantity at this point
thank you for you info a learn a lot.
gonzal12 is offline   Reply With Quote
Old 12-08-2010   #23
stevek is an unknown quantity at this point
Mechanic quoted me almost $400 for one sensor - and I am getting 38mpg still. After reading this, I think I will do it myself on 2000 HX.
stevek is offline   Reply With Quote
Old 12-09-2010   #24
Images: 178
i think hx may use different sensors than normal, maybe even 3 sensors.
Old 03-05-2012   #25
smokinlbz06 is an unknown quantity at this point
I have a 97 ex coupe, cel came on the other day, read the code (p0141 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2). Light is off now, fuel mileage seems lower. Could this be a bad sensor, a sensor that needs to be cleaned, or a wiring issue?
Any help would be appriciated.
Thanks
smokinlbz06 is offline   Reply With Quote
Old 03-05-2012   #26
Images: 178
the light will come and go if the sensor is below operating threshold. just replace it before it comes on again. most sensors start to lose noticable efficiency after only 20k miles.
Old 05-10-2012   #27
ekcoupe1 is an unknown quantity at this point
Where can you purchase these 2 sensors for cheap?? I need to replace them as well!
ekcoupe1 is offline   Reply With Quote
Old 05-11-2012   #28
Images: 178
www.hondaautomotiveparts.com i would get it directly thru honda dealer. there have been issues with other aftermarket parts having the wrong sensor inside. and the honda parts are not that much more. make sure you look up your exact vehicle because there could be different parts depending on the year/make/model/trim.
Old 05-15-2012   #29
kyle_l88 will become famous soon enoughkyle_l88 will become famous soon enough
Wow i just read this now and I know its old but to the guy that just asked the quesiton where to get them, I got them off amazon and they were like 30 a piece. Cheap in my books and been running fine for 20K km now.
kyle_l88 is offline   Reply With Quote
Old 03-26-2013   #30
mbergthold is an unknown quantity at this point
I'm working on my daughter's '94 Civic DX coupe, shows CEL 43. Already replaced the fuel filter, seems to have plenty of pressure, so O2's are next. I see the primary O2 in the exhaust manifold, but where the heck is the "downstream" sensor? I've looked underneath, had the exhaust disconnected when I replaced the steering rack, didn't see any wires going to the cat. If it really does exist, a picture would help me a lot. Thanks in advance!
mbergthold is offline   Reply With Quote
Thread Thread Starter Honda Civic Forum Replies Last Post
P0135 - HO2S Heater Circuit Malfunction Driving Me NUTS JetsterDajet Mechanical Problems/Vehicle Issues and Fix-it Forum 52 05-08-2016 01:11 AM
2001 honda civic LX exhaust manifold jdh022764 7th Generation Civic 18 11-03-2015 07:44 AM
1999 Civic DX hot start problem Bruce2 Mechanical Problems/Vehicle Issues and Fix-it Forum 1 09-21-2015 09:01 PM
02 civic Lx won't start. Help! 2.0.0.2 7th Generation Civic 1 09-14-2015 07:38 PM
96 Ex auto, sluggish/no acceleration dantheman42 Mechanical Problems/Vehicle Issues and Fix-it Forum 2 09-04-2015 02:10 PM
Tags
97, 98, changing, civic, cost, forum, front, ho2, honda, o2, oxygen, primary, replace, replacement, secondary, sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
All Content Copyright 2007 CivicForums.com
