Strange electrical issue.
Rep Power: 0 Strange electrical issue.
Hey, I'm not good with electrical issues and this could be something stupid or serious, I'm just not sure. It is a 98 civic dx.
So this has happened twice, first time I didn't witness it (happened to my fiancee) but this time I just saw it happen.
The first time this happened it was to my fiancee, she turned the car off in a parking lot and decided to turn it back on so she could listen to a song, the car was acting fine, got her to her destination just fine, but when she went to start it back up right after turning it off the car did absolutely nothing, no lights, no crank, no tick, radio, etc. I got a call from her, my friend and I got there, neither of us had a multimeter, but when we were jumping it it acted as if the battery was low after letting it charge for a minute.
The next day (today) the car was just started in a parking lot after doing numerous errands with no problems, but this time the radio shut off and came back on, then the srs (airbag) light came on. The car drove fine, we got it home, I turned it off and tried to start it right back up and there was nothing, no lights, the starter did nothing, it was as if the battery was 100% flat. I opened the hood and just moved the positive terminal a little and the headlights came on, checked the voltage on the battery and it was 12.5v, from there the car started back up. The previous owner had a radio amp on there, there was no fuse though, I took it off just in case. When the car is running the multimeter reads 14.5 volts, so the alternator seems okay.
Could there be a bad ground somewhere or could a bad terminal do this? I just pulled the positive terminal off as the car was running to see if I could replicate some of the symptoms, it did nothing strange, srs light did not come on and it did not mess with the radio. I'd think if the terminal was bad it would only effect start ups, but maybe I don't understand something.
Anyone know what could be going on?
Re: Strange electrical issue.
Rep Power: 0 Re: Strange electrical issue.
Thanks for the quick response.
Do you think that when driving or started a bad connection to the battery caused the ignition switch to malfunction causing all the other weird symptoms? It definitely all coincided with each other.
And thanks for the warning, I've seen people do it, never knew it was a danger, first time I had done it though, I won't do it again.
If it is taken out of the circuit, bad things can happen. Electronics can be very quickly affected.
Not always, but can.....and would be an expensive mistake if anything does go bad because of it.
There are plenty of real tools that can tell you if the charging system is working or not.
HTH
Received 1,131 Likes
Rep Power: 192 Re: Strange electrical issue.
I had an ignition switch go on me, and it would give me some weird no start issues, but it wouldn't act up when driving. I got a replacement (just the electrical portion) off rockauto for less that $40. It was pretty to install, just had to transfer a couple wires over from the old switch to the new one.
Click here if you want:
https://www.civicforums.com/forums/2...art-issue.html
Well for now it is working, It's been cleaned, I added a tiny amount of oil to the terminals, and positive and negative are both clean. I'm going to wait and see if it acts up again, if it does I will probably need new wires.
