99 civic sluggish on pickup
Old 12-08-2014
roverben's Avatar
roverben is an unknown quantity at this point
I have a 99 civic Si with automatic transmission and i don't know why it's always slow to pick up speed. Is there a kick down cable that needs to be adjusted or is there something wrong with the torque converter. For instance, if I'm driving @ 100kph and slow down to lets say 30kph and hit the gas again, that's when it takes a while to pick up speed again. Any suggestions. Thanks.
roverben is offline
Old 12-08-2014
Super Moderator
Poopies's Avatar
Re: 99 civic sluggish on pickup
What do you think? Is it failing to downshift or something?
Poopies is offline
Old 12-08-2014
roverben's Avatar
No, it's not failing to downshift.
roverben is offline
Old 12-08-2014
Does it not downshift when you do this?
Are you flooring the gas pedal when you do this? If you stab the gas pedal to the floor at 30KPH, it should downshift to second gear (it may even downshift to first.)
Pull the floormats out from under the gas pedal and try it again LOL.
Does it lack power otherwise? Will it pull hard all the way up to redline before it shifts?
ezone is offline
Old 12-08-2014
roverben's Avatar
There's no floor mat.(LOL) It's shifting fine, it's not picking up speed fast enough. It feels like I'm pulling something heavy.
roverben is offline
Old 12-08-2014
When you have the gas pedal floored: Will it pull hard all the way up to redline before it shifts?
Or does it shift long before redline when you have it floored?
ezone is offline
Old 12-08-2014
roverben's Avatar
I'll double check that later tonight and post findings.
roverben is offline
Old 12-08-2014
When the gas pedal is floored, is it pulling the throttle blade all the way open? Does the cable need adjustment?
ezone is offline
Old 12-08-2014
roverben's Avatar
will check that and post again.
roverben is offline
Old 12-09-2014
roverben's Avatar
It shifts long before the redline.
roverben is offline
Old 12-09-2014
If you had the gas pedal flat on the floor and it doesn't go all the way to redline before shifting, I'll first guess the throttle isn't reaching the "wide open" position for some reason.
Second guess might be a TPS related issue....I'd certainly get the scanner out and observe live operating data before pulling the trigger on any parts though.
ezone is offline
Crash2002
01-25-2002 01:04 AM
Cilvic
11-15-2001 04:54 PM
bambuski
11-12-2001 10:35 PM
Lightman
11-10-2001 06:44 PM
WeRkX
11-01-2001 10:33 PM
Quick Reply: 99 civic sluggish on pickup
