New To Honda need help
8MiL3
Rep Power: 0 New To Honda need help
Just bought a 2000 civic ex coupe when I hit 60 steering wheel and seemingly the front end shakes bad? What could it be... It pulls to the right so I'm thinking bad tire/rim and maybe need an alignment? Where can I find reasonably priced sensors have bad o2 and range
Re: New To Honda need help
A bad tire can cause shakes and cause it to pull one direction or the other. This may be your situation.
Shaking at speed has to do with balance of the spinning objects (tire and wheel), not alignment. (Alignment has to do with making all the wheels stand up straight and point forward.)
A tire that is no longer round can throw off the balance too.
If one clobbered a pothole or curb and bent a wheel and/or tweaked the suspension, then both tires/wheels and alignment can be affected. And more.
Have a pro evaluate the situation?
I'd test drive to verify the complaint and evaluate how it drives, then raise the car and spin the wheels, looking to be sure the tires all spin round and true and make sure none have obvious belt damage. If they are good, then balance them.
If a tire has obvious problems with the steel belts, balancing won't help and it needs replaced. A bad tire is dangerous.
O2 sensors.....Use whatever brand the factory installed. It will be DENSO or NTK.
Jessica Leung
05-05-2015 05:12 PM
jessicakaybby
04-20-2015 12:11 PM
Bartkat
20
02-19-2002 01:29 PM
