P1362 Code after Low Oil and Over-heating
Rep Power: 0 P1362 Code after Low Oil and Over-heating
99 Civic LX.
Over the weekend, the temperature gauge was nearing the red zone.
Coolant was low in the radiator and the oil dipstick was nearly dry. My fault...
Today, CEL is on with P1362 code, TDC sensor no signal.
1. Is it safe to drive the car this way?
2. Can it cause further damage?
3. Anything I could check before taking the car to the shop?
4. Could this code be related to the low oil level and heating issue from a few days ago.
I did add coolant and oil as soon as I discovered it.
Thank you.
Thank you.
Re: P1362 Code after Low Oil and Over-heating
Probably unrelated. Maybe influenced, but not directly related.
TDC sensor is inside the distributor.
You can ohm check the sensors, but replacement (if necessary) will involve a replacement distributor.
Warning: Aftermarket distributors are crap.
Check out this thread, the OP runs into a distributor code at about post #3, some troubleshooting follows: https://www.civicforums.com/forums/2...old-crack.html
Correct the lack of oil and coolant problem first.
Figure out where and why those fluids disappeared.
See if any damage occurred from the overheat event (blown head gasket, warped head, etc.). Damage may not be immediately apparent.
Rep Power: 0 Re: P1362 Code after Low Oil and Over-heating
I corrected the low fluid levels immediately upon discovering it.
How do I know if it actually overheated? The dial did not reach the red zone, but it was getting close.
How do I know if I have blown head gasket or warped head?
The car seems to be driving fine so far. I have deleted the code and am waiting to see if it comes back on.
I just don't want to cause additional damage by continuing to drive the car. Is that an issue?
Search here for blown head gasket, read about how a 7th gen acts when it has a blown head gasket. Yours may be similar. Find the sticky about overheating, there's a lot of info in that thread.
I can't predict the future LOL
HTH
Interesting. Before this happened I noticed that coolant levels were dropping in both the radiator and reservoir. I couldn't detect a leak anywhere.
I had a number of heating incidents, and every time noticed that coolant was low in both radiator and reservoir.
The radiator was replaced (by me) last year, and I just assumed that there were some air bubbles in it, although I tried to bleed them out.
Several lesser overheats can be just as bad as one big overheat.
Since coolant is disappearing, I'd pressure test the cooling system to try to encourage the leak to show itself, then Look harder for external leakage and evidence of leakage, maybe bring in some flashlights, a real car hoist, and a fresh set of eyes...
If that yields no results, maybe figure out some head gasket testing.
mattdoc
03-14-2017 12:10 PM
RIPSAW
11-06-2015 04:36 AM
jakeconnor
05-05-2015 07:30 AM
dooner24
04-14-2015 07:51 PM
