What do I have?
Rep Power: 0 What do I have?
Hi, I'm new to the Honda scene. My whole life i have been an American Muscle nut. I have built some hot rods and dirt track race cars, so I know my way around an engine and car plus i have a well equiped shop. Thing is is that my fiance has always wanted a Honda. So i bought one yesterday for her. I know what i bought in car terms, but not in Honda terms lol. So here is the info. If someone could break it down as to what i really have then i can get started on modifying it some, as I'll be damned if I'm going to have a stock car in my driveway.
1996 Civic LX 4-Door
1.6L SOHC w/108k miles(I know, low right?!)
Automatic transaxle
Now as its for my girl I don't plan on going full bore racecar with it. This is mostly for my addiction of modifying cars and it'll give her something to park next to my Warlock at the car shows. Mods I'd like to do after I refresh the engine with new rings/bearings are cam, small turbo, exhaust, computer. The suspension will get new shocks/struts if i can find performance stuff at stock ride height(she doesn't want it lowered) and some wheels/tires of her liking. So any info you guys can give me would be great! Thank you.
Automatic transaxle
Re: What do I have?
I would do quite a bit of research about your engine and its capabilities before throwing in a turbo. a 1.6 sohc wasnt made to push lot of power so even if you do end up turboing (which could run you in the ball park of 4-5000 for a good kit, and another 2 ish grand for intall) you'd have to run very low boost. Maximum 5 or 6 psi or you risk detonation
Prelude Owner
Re: What do I have?
Welcome!
He did say small turbo which if you built your own kit would not run you 4-5k. You could also run low boost (3-5psi) on stock internals.
Detonation comes from poor engine management and not sizing your system properly.
Rep Power: 0 Re: What do I have?
What do you have? A performance un-friendly engine/trans combo
My suggestion would be to leave the engine alone, unless you have a good chunk of change to do a Dohc engine /manual transmission swap that you'll further modify (forced induction, natural aspiration, etc)
Keep the mods simple and aesthetic only
Good luck.
Good luck.
