Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen
Register Forgot Password?
6th Gen In the years from 1996 to 2000 Honda released it's 6th Generation Civic. Chassis codes: EK9, EK4, EK3, EJ6, EJ8, EJ9, EM1
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools Search this Thread
Old 04-11-2012   #1
TyBardy is an unknown quantity at this point
Dome light not working properly
My dome light does not come on when the doors are open, I cant seem to find a fuse for this... am I missing something? Why wont it come in when the doors open? It does work, just not when the doors open.
TyBardy is offline   Reply With Quote
Old 04-11-2012   #2
Super Moderator
Images: 178
gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute
Re: Dome light not working properly
if it works, the fuse is fine. more than likely its a door trigger (or two) not working.
__________________
2002 Honda Civic EX Auto
gearbox is offline   Reply With Quote
Old 04-11-2012   #3
it doesnt work with any of the four doors.
Old 04-11-2012   #4
Super Moderator
Images: 178
i meant if you are able to manually turn the lights on in the ON position, the fuse is fine because the bulbs are getting power. do any of the chimes work if the key is in the ignition or the lights are on and the driver door is open?
__________________
Old 04-11-2012   #5
The chime does work... when the lights are on and I open the driver door I get the annoying chime.
Old 04-11-2012   #6
Super Moderator
Images: 178
so its not the door switches then. im not sure about the 6thgen wiring, but on the 01+ civic the dome lights are tied to the MCU (multiplex control unit) and its possible that went bad. not sure if you have one either. the MCU is designed so that if one part fails (like dome light circuit), the other systems will continue working. so it will be hard to trace the issue, but thats what it sounds like to me.
__________________
Old 04-11-2012   #7
ugadawg187 is an unknown quantity at this point
Do you have a aftermarket radio? If so they wont work
ugadawg187 is offline   Reply With Quote
Old 04-11-2012   #8
azkicker0027's Avatar
azkicker0027 is an unknown quantity at this point
also check the dome light assembly itself. i've seen the housing warp where the contacts are not supported properly.
azkicker0027 is offline   Reply With Quote
Old 04-12-2012   #9
Quote:
Reallly??? Why??? Yes, I purchased the car and it already had an aftermarket stereo system installed. I want to replace it but I certainly don't want to replace it with an old factory unit.
Whats the deal with this and is there a way to fix it... and I suppose while I am on the subject of radio, is it also possible to get a remote access to my car without putting the factory radio back in as I understand that too is tied to the radio.
Why the hell did Honda tie everything into the radio?
Old 04-12-2012   #10
Super Moderator
Images: 178
thats only for 97-98 civics where removing the stock radio will kill the dome light and keyless entry system. there is a bypass harness that lets you mount the stock radio inside the dash and then connect it to a second aftermarket unit to keep keyless and dome light.
__________________
Old 04-12-2012   #11
GD crazy honda's... where can I find one of these bypass harnesses? I will obviously need to get a stock radio as well... anything I should know here?
Old 04-12-2012   #12
Super Moderator
Images: 178
best buy should have everything you need. check ebay for a stock radio usually around $25 or so. it just has to be working, doesnt need to be pretty looking. or if dome and keyless is not that important, dont worry about it.
__________________
Old 04-12-2012   #13
will a 99 head unit work?
Old 04-12-2012   #14
Found a 99-00 am/fm only head unit on ebay for $17... I have a 98 civic... will this work?
number is 39100-S10-A210-M1
Old 04-13-2012   #15
Super Moderator
Images: 178
no it must be a 97-98 because only those decks have the dome and keyless circuits built into them. even if the 99-00 plugs in (it prolly doesnt), the dome and keyless still would not work.
__________________
Old 04-13-2012   #16
danwat12345 has a spectacular aura about danwat12345 has a spectacular aura about
There are 2 power lines going to the dome light fixture. One is 12V, for the "ON" position. the other is a bit less voltage, and is used for when a door opens. Then there is case ground to complete the circuit.
__________________
1999CivicDX with train horns from hornblasters, 55w HID headlights, 35w DDMtuning HID back-up lights (for when driving backwards, mounted in stock reverse light fixture) Cheap $11 side fog lights from Harbor Freight for side illumination for neighborhood street corners.
Oznium Superflux 16-LED dome light, CCFL Logisis 12" white underseat illumination and mounted on ceiling of trunk via duck tape.
Genuine locomotive E-bell zip tied &u-bolted inside back bumper. Trailer hitch.
5/1/2013: 230K miles. 2KW inverter, 160Amp alternator. 19mm rearsway
205/50/R16 tires, biggest u can safely use on stock suspension. Train horn vids; Youtube 'danwat1234'
30.5MPG average on Fuelly. Auto tranny, d16y7
danwat12345 is offline   Reply With Quote
Old 04-13-2012
CivicForums
Honda Civic
Paid Advertisement
Tags
99 , car , civic , dimming , doam , dome , door , durango , honda , lighr , light , lights , open , wont , working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
Shifting problem, won't go into gear
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
96-00 ex rear disc conversion?
Power Window issues on my 96 EX
Tire Size
1998 Honda Civic Automatic Transmission slippage
Valve Cover Gasket
97 Civic RPM Fluctuation when Driving
Advertising - Privacy Statement - Terms of Service - Jobs
All Content Copyright 2007 CivicForums.com
Emails Backup
