Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen
Register Forgot Password?
6th Gen In the years from 1996 to 2000 Honda released it's 6th Generation Civic. Chassis codes: EK9, EK4, EK3, EJ6, EJ8, EJ9, EM1
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools Search this Thread
Old 02-10-2012   #1 (permalink)
Points: 34, Level: 1
Points: 34, Level: 1 Points: 34, Level: 1 Points: 34, Level: 1
Level up: 68%, 16 Points needed
Level up: 68% Level up: 68% Level up: 68%
Activity: 2.2%
Activity: 2.2% Activity: 2.2% Activity: 2.2%
shemp1 is an unknown quantity at this point
Changed plugs, started great, quit after 5 mins, now won't start
I have a 2000 Civic Si, no major problems with it. Just changed my cap and rotor (honda parts), wires (NGK) and plugs (NGK Iridium power). I cleaned my battery a bit with some baking soda and water. I have been doing most of my own repairs for 20 years. The car started right up and ran smooth and while I was cleaning up and letting the ECU recalibrate (I had the neg battery wire off previously) the suddenly stopped running. I have not been able to start it since. It turns over real strong but acts like the thing has no spark or fuel.
I did leave off the internal safety shield that used to be in the cap since it made it hard to get at the rotor screw. I assume this just acted as a high voltage safety barrier for the mechanic but has no other function. I recall all the wiring looked real tight to the distributor body, so can't see any issue with leaving it off.
Help!
shemp1 is offline   Reply With Quote
Old 02-10-2012   #2 (permalink)
Points: 143, Level: 2
Points: 143, Level: 2 Points: 143, Level: 2 Points: 143, Level: 2
Level up: 86%, 7 Points needed
Level up: 86% Level up: 86% Level up: 86%
Activity: 33.3%
Activity: 33.3% Activity: 33.3% Activity: 33.3%
em2brasil is an unknown quantity at this point
Re: Changed plugs, started great, quit after 5 mins, now won't start
re check all you did. take the dizzy cap off again check the rotor? did u drop the spark plugs in ? or did u place them in with the spark plug socket? pull those out the check.
em2brasil is offline   Reply With Quote
Old 02-10-2012   #3 (permalink)
Should Plastic Jesus watch the road or watch me?
Location: Standing at the corner of WALK and DON'T WALK
Points: 13,771, Level: 76
Points: 13,771, Level: 76 Points: 13,771, Level: 76 Points: 13,771, Level: 76
Level up: 31%, 279 Points needed
Level up: 31% Level up: 31% Level up: 31%
Activity: 99.9%
Activity: 99.9% Activity: 99.9% Activity: 99.9%
ezone has much to be proud of ezone has much to be proud of ezone has much to be proud of ezone has much to be proud of ezone has much to be proud of ezone has much to be proud of ezone has much to be proud of ezone has much to be proud of ezone has much to be proud of ezone has much to be proud of ezone has much to be proud of
LOL #youcantbeserious OMGWTFBBQ Seriously? I'm not 12.
Quote:
So see if it has spark and fuel.
Quote:
safety shield
Put it back, it was in there for a reason.
A missing coil shield can cause P1381 code.
ezone is offline   Reply With Quote
Old 02-10-2012   #4 (permalink)
Activity: 2.2%
I was only able to get back to the car at the end of the day. I pulled the dist., the rotor looked fine. I took it off and put the shield back on. Had the neg terminal of the battery off in case the ECU needed to reset. Still does not start.
I put the plugs in with the socket, finger tight and then a half turn. I don't see anything wrong. I did notice that the spark coils only has a spring on it and was wondering if I dropped some other piece that would touch the terminal in the cap. After looking online it doesn't seem so.
I guess I'll buy an OBD-II reader and see if anything pops up.
Like I said, it ran for 5 mins real smooth so this is bizarre. I called my mechanic and he said the computer shouldn't shut things down if there is anything weird and the only thing he could think of is a broken rotor, which it is not.
The car has been running pretty well for years and I doubt something unrelated happened coincidentally.
Any other ideas????
Old 02-10-2012   #5 (permalink)
Activity: 99.9%
So, does it have spark and fuel?
Old 02-14-2012   #6 (permalink)
Points: 175, Level: 3
Points: 175, Level: 3 Points: 175, Level: 3 Points: 175, Level: 3
Level up: 50%, 25 Points needed
Level up: 50% Level up: 50% Level up: 50%
Activity: 1.1%
Activity: 1.1% Activity: 1.1% Activity: 1.1%
ARMprod is an unknown quantity at this point
check for all the negatives to be on tight
ARMprod is offline   Reply With Quote
Old 02-14-2012
CivicForums
Honda Civic
Paid Advertisement
Tags
2000 , 2002 , cap , changed , civic , honda , located , plugs , quit , rotor , si , spark , start , vtec , wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
Shifting problem, won't go into gear
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
96-00 ex rear disc conversion?
Tire Size
Power Window issues on my 96 EX
My new 4th gen hatch
97 Civic RPM Fluctuation when Driving
1998 Honda Civic Automatic Transmission slippage
Contact Us - Honda Civic Forums - Honda Civic News - Archive - Top
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Emails Backup
