OBD-II Protocol for '99 Civic?
Old Aug 15, 2011
nothsa's Avatar
nothsa is an unknown quantity at this point
Question OBD-II Protocol for '99 Civic?
Hi,
I'm wanting to buy an OBD-II bluetooth device for my Canadian '99 Civic CX. I've done a bunch of research on OBD-II, and right now I'm trying to find out which protocol is used on my vehicle.
I've looked through the owners manual and the stickers on my car, and none of them specify the protocol. I've also checked the pins on my OBD-II connector, and the contact pin configuration (4, 5, 7, 14, 16) doesn't match any of the protocols that I can find. The closest is ISO 9141/14230, but that is supposed to have pin 15, not 14.
Can anyone confirm the protocol, or at least point me to a place where I can find it? I would hate to waste money buying a device that doesn't support the protocol used on my car =/
Old Apr 25, 2012
civicpat's Avatar
civicpat is an unknown quantity at this point
Re: OBD-II Protocol for '99 Civic?
Hi,
Did you end up finding what protocol this was??
I have the same problem as you.
Thanks
Old Apr 25, 2012
Stock 99's Avatar
I just plugged my OBD II reader into my '99 DX (Canadian) for you. It connects on ISO 9141.
Old Apr 26, 2012
blackomen's Avatar
blackomen is an unknown quantity at this point
I bought an OBD II reader off of Amazon that connects to my Laptop. Works right out of the box with my Stock '99 Civic LX.
Old Apr 26, 2012
matthew_burnett's Avatar
matthew_burnett is an unknown quantity at this point
I use the elm 327 in my 98 ex. it reads it perfect. only had a problem reading ford vehicles. I use constantly. I think I paid like 20 bucks on ebay for it
Old May 1, 2012
civicpat's Avatar
I am also using a ELM327 circuit that I built to connect to my 00 civic.
I am manually setting its protocol to ISO9141 and forcing a slow bus initialization then sending the 01 00 PID command to tell me what PIDs are supported and to test the connection. The bus initializes correctly but I get no response when sending the 01 00 command... -_-
Old May 24, 2012
nothsa's Avatar
Originally Posted by civicpat
Hi,
Thanks
It's ISO 9141. The "Torque" app on my phone lists it as "ISO 9141-2 (5b init, 10.4k baud)"
Cilvic
Nov 15, 2001 04:54 PM
bambuski
Nov 12, 2001 10:35 PM
Lightman
Nov 10, 2001 06:44 PM
locozoko
Nov 4, 2001 05:45 PM
WeRkX
Nov 1, 2001 10:33 PM
