99 power windows not working
Rep Power: 0 99 power windows not working
Hi all,
The power windows in my 99 civic ex stopped working. I checked the 40amp under the hood fuse box and the 20Amps on the inside. The moonroof/power window relay 7.5 amp is ok, too. The moonroof works fine. No other electrical problems. Can anyone help me?
Thanks in advance.
Thanks in advance.
Re: 99 power windows not working
Hi all,
Thanks in advance.
Thanks in advance.
If that is the case, might be a bad master switch. Also, I forgot the name of the part but in the drivers door there is a box that can go bad, I believe it can knock out all the windows.
There is a controller box in the door itself as well. Get a repair manual, and there is a test procedure for the master switch to determine if it is bad. I would go that route before just replacing parts.
got2kids
05-09-2015 06:45 PM
ORskier
05-03-2015 12:54 PM
