Valve Cover Gasket
Old 07-19-2009
Mavrick272's Avatar
Mavrick272 is an unknown quantity at this point
Valve Cover Gasket
Hey, I need to replace my valve cover gasket, as there is oil pooling on top of my header. I know lots of you have done this before and I was wondering if you would be so kind as to share some tips, do's and dont's (And maybe a link to a DIY...) as I have never done it before. I was also thinking about maybe painting the valve cover since I'm going to have it off.
Any info would be greatly appreciated!
Thanks
Mavrick272 is offline
Old 07-22-2009
ScottDR's Avatar
ScottDR will become famous soon enough
Re: Valve Cover Gasket
Well, it's incredibly simple:
1. pull spark plug boots off of plugs
2. remove 5 bolts
3. lift off valve cover
4. remove gasket (will stick to cover or head)
5. dry oil off of all mating surfaces
6. put new gasket in valve cover
7. replace valve cover
8. replace 5 bolts (DO NOT OVERTIGHTEN!) in 3 steps...final torque is 7.2 pounds (yes, very very light).
9. reinstall spark plug boots
ScottDR is offline
Old 07-23-2009
Mavrick272's Avatar
I spent a few hours reading the PDF of the 6th Gen service manual and came to the same conclusion; it is quite simple. Just wanted to be safe! Thanks for the info though
Old 07-23-2009
ScottDR's Avatar
You are welcome. As I mentioned before, just don't overtighten the bolts! Seven ft. pounds is extremely light.
ScottDR is offline
Old 07-23-2009
JREJ8's Avatar
JREJ8 is an unknown quantity at this point
super easy pull off the valve cover and pull off the old gasket and put the new one on. easy
JREJ8 is offline
Old 07-24-2009
sql_civic's Avatar
WRONG!
This is real important...
Apply sealant to the corners of the humps in the valve cover. This is where the cover goes up and over the cam. Use either Hondabond (avalable from your Honda Stealership) or Permatex Ultra Grey (available at any auto parts store). If you don't do this your cover will leak.
sql_civic is offline
Old 07-24-2009
ScottDR's Avatar
Sql: I haven't used any sealant since my 1987 Prelude (sold running perfectly at 180,000 miles-did valve lash adjustments every 15,000 miles faithfully). I used to adjust my valves on my 5G Civics every 30,000 miles and never used any with no leaks etc. I adjusted valves once on both of my 6G's (d16y8 and d16y7) with no leaks after not applying any sealant.
That being said, yes Honda service manuals have always recommend using them in those locations. And yes, Hondabond and Permatex Ultra Gray are essentially identical.
ScottDR is offline
Old 07-25-2009
Mavrick272's Avatar
Yeah, I remember reading that in the service manual. I have some good Permatex that I plan on using. A mom and pop shop did the valve cover gasket 6 months ago and it held for awhile but then started leaking about 2 months ago. I think they forgot to Permatex. I was about to take it back but then decided to paint the valve cover so I thought what the hay, I'll have it off anyway...
Old 07-25-2009
JREJ8's Avatar
Originally Posted by sql_civic
WRONG!
dude ive never used sealant on any of my valve covers and theres never been a leak. so if you want to waste your time and money go ahead, but i dont so WRONG!
JREJ8 is offline
Old 07-25-2009
Mavrick272's Avatar
I figure it can't hurt, right?
thanks for the opinions though, guys
Old 07-25-2009
ScottDR's Avatar
No, it can't hurt at all. Just make sure you use Ultra Black (sticks to aluminum) or Ultra Grey (better as it's for aluminum, high temp AND pressure). If the old one is leaking, it's most likely torn or damaged in some way.
ScottDR is offline
Old 07-25-2009
ScottDR's Avatar
ScottDR is offline
Old 07-29-2009
sql_civic's Avatar
Listen kid, I've got so much more experience than you with Hondas and other cars/engines it just makes laugh at your ignorant comment. But that's ok, you go ahead save your precious time and money - eventually you'll grow up and learn from your mistakes.
Old 08-26-2009
rpfn140378's Avatar
rpfn140378 is an unknown quantity at this point
Hi guys,
I’m new here and I found this forum on the internet while looking for some information about Valve Cover Gaskets, I own a 2001 Civic 1.4 sport, the ones that came out until March 2001, if I’m not wrong, ( Between 1996, I think, to 2001), the car has now 54000 miles and I have noticed some wet stuff around the Valve Cover gasket. I was planning to buy a spark plug torque wrench to change the spark plugs my self, is not the first time I do this, but not in this car, so this time I want to do it right with the right tightening torque.
I thought I could tight the valve cover a bit more, to prevent the leak to go further, am’ I right? That’s why I’m asking to hear the everyone’s opinion.
I just read some information about the tightening torque for the Valve Cover Gasket, so I thought I could use a bit more in it to prevent leaking without buying a new gasket right now, and then in next service I could do it and saves me some money for now.
I would be really appreciate if someone can give me some opinion.
rpfn140378 is offline
Old 09-06-2009
sql_civic's Avatar
I've had some success tightening down bolts to slow down or stop leaks. BUT BE REAL CAREFULL. THOSE BOLTS BREAK EASY.
Old 07-21-2010
madvladcivic's Avatar
madvladcivic is an unknown quantity at this point
WRONG!
Hi,
I'm new to this forum.
I know this topic is nearly 1 yr old but....
Re Permatex ultra grey (82194). What's the diff btw/ ultra grey
and Permatex ultra copper (81878)? Other than the high temp
limit. Can ultra copper be substituted for ultra grey in applications
involving the valve cover gasket or the oil pan gasket? Is the
high-torque vibration resistance parameter what makes this RTV
silicone desirable?
Thanks.
MVC
madvladcivic is offline
Old 07-22-2010
Nosepicker's Avatar
Nosepicker is a jewel in the roughNosepicker is a jewel in the roughNosepicker is a jewel in the roughNosepicker is a jewel in the rough
Thx for the bump...subscribed.
Nosepicker is offline
Old 07-25-2010
ScottDR's Avatar
The Ultra Grey is for higher pressure and is extremely similar to Honda Bond and will stick to different materials.
ScottDR is offline
Old 09-09-2013
2000 Civic DX
Niblet's Avatar
Niblet is an unknown quantity at this point
Should you buy a genuine Honda valve cover gasket or one from auto zone??
Niblet is offline
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
03-28-2022 07:35 AM
Fudman
Suspension
02-01-2020 04:13 PM
Mercilus
06-07-2015 10:00 PM
JohnnyBxo
16
05-09-2015 05:53 PM
CascadiaBlue
04-18-2015 09:13 AM
Quick Reply: Valve Cover Gasket
