Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen
Sign in using an external account
Register Forgot Password?
6th Gen In the years from 1996 to 2000 Honda released it's 6th Generation Civic. Chassis codes: EK9, EK4, EK3, EJ6, EJ8, EJ9, EM1
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools Search this Thread
Old 04-09-2008   #1
fbruno is an unknown quantity at this point
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
I have a 1998 Civic EX with a single overhead cam engine and need to find the location of the solenoid valve and oil pressure switch on the engine.
I have a haynes manual and it only shows the dual overhead cam engine.
fbruno is offline   Reply With Quote
Old 04-11-2008   #2
lemac's Avatar
Images: 6
lemac will become famous soon enough
Re: Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Click the image to open in full size.
Hope this helps
lemac is offline   Reply With Quote
Old 04-15-2008   #3
BoneStOck_176's Avatar
BoneStOck_176 is an unknown quantity at this point
Send a message via AIM to BoneStOck_176
and the location of the solenoid applies to a 00 SOHC as well... Right!!?
BoneStOck_176 is offline   Reply With Quote
Old 04-15-2008   #4
Super Moderator
Images: 178
gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute
i dont think the shape changed much over the years
gearbox is offline   Reply With Quote
Old 04-21-2008   #5
lambada is an unknown quantity at this point
Is it any different on a B16A2 engine? I can't seem to find one? It should be towards the back of the engine bay right?
Is it true that this solenoid should be heard clicking when the engine is revved even if it is in neutral?
lambada is offline   Reply With Quote
Old 04-21-2008   #6
Super Moderator
Images: 178
nope, the solenoid will not engage just revving in neutral. it should be bolted somewhere to the cylinder head. if its not, then you dont have vtec.
__________________
2002 Honda Civic EX Auto
Old 08-11-2010   #7
kurtdaniel is an unknown quantity at this point
Quote:
Hope this helps
i have the same inquiry..good thing i found this thread..this is very helpful..
kurtdaniel is offline   Reply With Quote
Old 01-17-2011   #8
emicha is an unknown quantity at this point
Who sells just the oil pressure switch?
emicha is offline   Reply With Quote
Old 01-18-2011   #9
Moderator
sdaidoji is a splendid one to behold sdaidoji is a splendid one to behold sdaidoji is a splendid one to behold sdaidoji is a splendid one to behold sdaidoji is a splendid one to behold sdaidoji is a splendid one to behold sdaidoji is a splendid one to behold sdaidoji is a splendid one to behold sdaidoji is a splendid one to behold sdaidoji is a splendid one to behold sdaidoji is a splendid one to behold
sandro daidoji
Send a message via ICQ to sdaidoji Send a message via Yahoo to sdaidoji
delete edit
__________________
02 Coupe EX
suspension basics, Engine codes - To read, not to ask, Honda swap 101, VTEC head swap, Chassis code?, EX header?, cam?
Quote:
Originally Posted by Poopies View Post
I get the broke thing, but what does being female have to do with anything? We'd help you out if you were a lawn gnome as long as you asked us nicely!
sdaidoji is offline   Reply With Quote
Old 01-18-2011
CivicForums
Honda Civic
Paid Advertisement
Tags
01 , 04 , 93 , civic , honda , located , location , oil , pressure , solenoid , switch , sylenoid , valve , vlave , vtec
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
Shifting problem, won't go into gear
96-00 ex rear disc conversion?
Power Window issues on my 96 EX
Tire Size
1998 Honda Civic Automatic Transmission slippage
Valve Cover Gasket
97 Civic RPM Fluctuation when Driving
vBulletin Skin by ForumTemplates.com
Advertising - Privacy Statement - Terms of Service - Terms of Service - Jobs
All Content Copyright 2007 CivicForums.com
Emails Backup
