Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen
Register Forgot Password?
6th Gen In the years from 1996 to 2000 Honda released it's 6th Generation Civic. Chassis codes: EK9, EK4, EK3, EJ6, EJ8, EJ9, EM1
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools Search this Thread
Old 03-03-2008   #1
DPBlom is an unknown quantity at this point
Bench test an ECU?
Hello All -
I have a 1996 Civic DX with a D16Y7 engine. The original engine had 330,000Km on it when I replaced it with a used D16Y7. Wiring harness, intake manifold & fuel injectors, and exhaust manifold from original engine were retained. 'New' engine now turns over, but there is no fuel pumping & there is no spark. I have verified the fuel pump by supplying power to it directly & have also verified that the coil will produce a spark. Have also gone over all harness connectors & checked for loose or missing ground wires, etc. - all seems OK. I have a Haynes manual & have checked resistances & levels of various ignition components & also checked the fuel pump relay & all are within spec. The Check Engine light goes out when I turn the ignition to on & the motor turns over. Tried shorting the plug on the right side near the ECU to get trouble codes to blink when the key is turned on, but no codes appeared. Bought a ProScan Universal scan tool w. USB interface from Gore Research (cool toy!), but it indicates it can't talk to the ECU. Have disconnected & reconnected the battery to reset things, but no joy. It is looking to me like the ECU is cooked, but I would have expected some kind of error indication if this were true - at least the 'check engine' light should turn on?! Does anyone know if there is any kind of bench test that can be done to verify the ECU? I'd like to be a little more confident that it is broken before swapping in another one.
Thanks,
Dave
DPBlom is offline   Reply With Quote
Old 03-05-2008   #2
sql_civic's Avatar
sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light
Re: Bench test an ECU?
Have you checked if the fuel pump has power? When you turn the ignition do you hear the pump whir and then click?
It sounds like a similar problem I had which turned out to be the ground at the thermostat housing. I thought I had a good ground there as well. Just for ***** disconnect that ground and clean the mating surfaces and reconnect it.
The best way to bench test the ECU is to find someone else with a 96-98 DX or LX and put your ECU in there.
sql_civic is offline   Reply With Quote
Old 03-18-2008   #3
Doh!
I *thought* all the grounds were good...
Pried the harness out of the way to check the thermostat housing ground & there it was, flapping around in the breeze. Cleaned it up & bolted it down & & after a lot of coughing & hacking it fired up!
Thanks for suggesting I check again!
Old 03-18-2008
CivicForums
Honda Civic
Paid Advertisement
Tags
94 , bench , bunch , civic , ecu , fuel , harness , honda , light , power , spark , test , tester , testing , turns
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
Shifting problem, won't go into gear
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
96-00 ex rear disc conversion?
Power Window issues on my 96 EX
Tire Size
1998 Honda Civic Automatic Transmission slippage
Valve Cover Gasket
97 Civic RPM Fluctuation when Driving
Advertising - Privacy Statement - Terms of Service - Jobs
All Content Copyright 2007 CivicForums.com
Emails Backup
