Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen
Sign in using an external account
Register Forgot Password?
6th Gen In the years from 1996 to 2000 Honda released it's 6th Generation Civic. Chassis codes: EK9, EK4, EK3, EJ6, EJ8, EJ9, EM1
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools Search this Thread
Old 10-02-2007   #1
Nitro Express is an unknown quantity at this point
Tire Size
Hi, I am new to this forum. I just bought a 2000 Civic EX (clean car, low miles, perfect condition). It has the stock 185 x 65 x 14 tires on it. I will be using this car as a daily driver but I want to make some suspension (strut tower brace & rear sway bar) and tire upgrades. Can I put 205 x 50 x 16 tires on this car (without any concern of rubbing under any normal condition). I realize that people have put much large tires on these (but at what cost). My inclination is to stick with the 195 x 55 x 15 size, but going to the 205's would look so much nicer. Does anyone have any first hand experience here? Thanks for the help.
Nitro Express is offline   Reply With Quote
Old 10-02-2007   #2
sql_civic's Avatar
sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light
Re: Tire Size
I'm running American Racing 15" Aero wheels with Nitto NT-450 205/50s on a 97 Civic HB. It's the same generation as your car so it should work for you as well. I only get a little rubbing when turning the wheel all the way to the left or right. I'm riding on the stock suspension (not lowered IOW).
Be careful about adding sway bars unless you know for sure how it will effect the over/under steering on your car.
Good Luck.
sql_civic is offline   Reply With Quote
Old 10-03-2007   #3
Re: Tire Size
Thanks for the info. I will likely go with the 195/55/15; I really don't ever want any rubbing. As for the sway bar how will know unless I put it on. I will leave the front one stock. In the rear I was planning on using a 19mm bar.
Old 10-07-2007   #4
sql_civic's Avatar
Re: Tire Size
Read all about it here. You don't want to find out you messed up your suspension by hitting a tree.
Old 10-07-2007   #5
greeen01civic4d's Avatar
greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold
Re: Tire Size
r u planning on gettin rims?? cuz if not, ur stuck with 14's
greeen01civic4d is offline   Reply With Quote
Old 10-08-2007   #6
mugenpower89's Avatar
mugenpower89 can only hope to improve
Send a message via Skype™ to mugenpower89
Re: Tire Size
my guess is they'll work but r u plannin on gettin rims?
mugenpower89 is offline   Reply With Quote
Old 10-09-2007   #7
Re: Tire Size
Well yes, I now have 185/65/14 if I go to 195/55/15 that would mean I need differant rims. I would love to get 205/45/16 but I am afraid of rubbing. Especially if I lower the car by 1.5". The 15" rims will work well, I don't want to build a race car, just a really good highway car... The car is 100% stock now, I want to make sure I thoink it all through.
Old 10-15-2007   #8
mrplow123456's Avatar
mrplow123456 will become famous soon enough mrplow123456 will become famous soon enough
Re: Tire Size
I recently took my 17" Axis rims off. I had 205/40-17 Dunlop FM901s on them and had no concern of rubbing. The car is at stock height too.
mrplow123456 is offline   Reply With Quote
Old 10-15-2007   #9
Re: Tire Size
Thanks, that's good to know. One of my concerns is that I would like to lower the car by 1.5". I'm still thinking about which way to go on this one. The lowered suspension and wheels will be the last thing I do, so I have a bit of time. If I ran into a great deal on 16" or 17" rims, that would effect which way I go. Thanks for the info.
Old 10-15-2007   #10
Re: Tire Size
No problem. I have been told you can fit up to 18's under a stock civic but u have barely any tire. Just do some research on lowering and keep us informed on the car.
Old 03-31-2008   #11
TheJGB3's Avatar
TheJGB3 is an unknown quantity at this point
Re: Tire Size
I would recommend the 205/45R16 (Honda Fit OE size) size if you want 16" wheels. This is a +2 fitment for the 185/65R14 OE tire and a +1 fitment for the SI 195/55R15.
TheJGB3 is offline   Reply With Quote
Old 03-31-2008   #12
silver2 is an unknown quantity at this point
Re: Tire Size
I just went from stock 14" tires and wheels with cheap Michelin Pilot's to alloy's with 195/60/15 Falken Ziex. The tires are a bit taller than they should be so there's a little speedometer error. However, the ride is fantastic. Quiet and smooth. I couldn't believe the improvement.
When I switched from a big American sedan to the Civic, I was delighted with the stock Civic handling. If you can improve it, that's fine. For a driver, it is more than adequate. Quality tires are a must. Anything else may sacrifice ride quality although excellent handling makes it a joy to drive.
silver2 is offline   Reply With Quote
Old 04-16-2012   #13
b.macfarlane is an unknown quantity at this point
Re: Tire Size
I have a 2000 Honda civic and I just bought 15 inch rims and the tire size is 195 55 r15 . The car isn't lowered , and it's the sedan 4 door . Should I be concerned about rubbing or will they fit ?
b.macfarlane is offline   Reply With Quote
Old 02-14-2015   #14
dj84 is an unknown quantity at this point
Re: Tire Size
Ive got a 98 civic pretty much slammed i want rims and ive got.a good deal on a set of 17s but i need to know wat tire size i need bc the rima have no tires. Can sum 1 plz help me?
dj84 is offline   Reply With Quote
Old 02-14-2015
CivicForums
Honda Civic
Paid Advertisement
Tags
07 , 1996 , 2000 , 2003 , 2007 , civic , honda , lx , put , size , standard , stock , tire , tires , wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
Shifting problem, won't go into gear
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
96-00 ex rear disc conversion?
Power Window issues on my 96 EX
Tire Size
1998 Honda Civic Automatic Transmission slippage
Valve Cover Gasket
97 Civic RPM Fluctuation when Driving
vBulletin Skin by ForumTemplates.com
Advertising - Privacy Statement - Terms of Service - Terms of Service - Jobs
All Content Copyright 2007 CivicForums.com
Emails Backup
