Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 11-10-2009   #1 (permalink)
bigjohn12858
New Member
bigjohn12858 is an unknown quantity at this point
99 LX Surging...
Just put the front end of the LX together. The cruise module was smashed, put a new one in, it works. When idling, car "surges" about .5K RPM, from 1K-1.5K, like somebody regularly pumping gas. Doesn't happen at speed or with A/C on. I've checked the Vac system, all looks good. Could there be a little one hidden somewhere I'm missing??? Car sat up for about a yr or so with smashed front. Thanks. To remove this ad, register today for free or log in if already registered!
bigjohn12858 is offline   Reply With Quote
Sponsored Links
Old 11-10-2009   #2 (permalink)
Cleft_Asunder
Diamond Member
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light
Re: 99 LX Surging...
What do you mean by "put together?" An automatic IAC valve on a 5-speed throttle body will cause it to behave like that.
__________________
'97 Civic DX 5-speed: Keyed to perfection.
http://www.civicforums.com/forums/signaturepics/sigpic34179_1.gif
Updated 96-00 timing belt DIY
Cleft recommends Raxles axles
Cleft_Asunder is offline   Reply With Quote
Old 11-10-2009   #3 (permalink)
bigjohn12858
New Member
Ah, sorry, It was in a front-ender. Replaced the left front fender, both headlight assemblies, hood, and radiator support. Oddly, the airbags didn't deploy, but then agian bulk of impact was above the bumper-even re-used the grille. Didn't mess up radiator or anything else except the cruise module. It's an automatic 4cyl.
Old 11-10-2009   #4 (permalink)
Cleft_Asunder
Diamond Member
It's hard to say. It could be an air leak, a dirty IAC valve, or even a leak in the radiator/hoses. I had the same problem because the previous owner somehow put a hole in the intake manifold metal coolant barb. I had it welded up. But I also cleaned my IAC valve and throttle body which also was a factor.
I would start by making sure you don't have coolant leaks. Run the car with the radiator cap off, heat and fans to max to get out any air trapped in the system. Then, put the cap on and see if it idles properly. If it didn't fix it, clean the IAC/throttle body. Don't touch the idle screw.
__________________
Old 11-11-2009   #5 (permalink)
bigjohn12858
New Member
Thanks, I'll give that a try. Don't think there is any coolant leaks as I've never noticed any spots under it in the driveway, even after idling for a while, and the system hasn't been fooled with.
Old 11-11-2009   #6 (permalink)
bigjohn12858
New Member
Changed the IAC (NOT cheap) but that did the trick. Had to adjust the idle a little, but no more surging...Thanks Clef!!
Tags
6th , 98 , adjustment , airbags , belt , body , civic , cleaning , deployed , gasket , gen , honda , iac , lx , pictures , throttle , timing
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
My new 4th gen hatch
Shifting problem, won't go into gear
96-00 ex rear disc conversion?
Power Window issues on my 96 EX
Tire Size
Turbo Kit for D16Y8 (44K miles)
97 Civic RPM Fluctuation when Driving
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
