Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 2 Weeks Ago   #1 (permalink)
Ironliftr3
New Member
Ironliftr3 is an unknown quantity at this point
Air Intake Question on DX
Hey guys, I've done a bunch of reading on air intake systems, and I'm avoiding the typical newbie questions (hopefully!). Decided the way to go is a Weapon R Secret Weapon, and I understand I should replace the provided filter with an AEM.
Question - I have a 98 DX, non-VTEC. I realize I'm limited with my options with this engine. Is upgrading the air intake a worthwhile investment, or a total waste of money on this case? I'm not looking to just 'sound cool'.
Thanks!
Ironliftr3 is offline   Reply With Quote
Sponsored Links
Old 2 Weeks Ago   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: Air Intake Question on DX
no not in the case of secret weapon filter. it uses a dense oiled foam that flows more air and filters better than anything else available. the SW1 filter is THE BEST filter you can buy in terms of filtration and airflow. it actually has a velocity stack design to suck more air than an open pipe. get yourself a good foam filter cleaner kit like UNI and clean/oil it every 6 months for best airflow. ive had mine for several years and it traps even the smallest dust particles. the intake tube and all the idle/air components are still squeaky clean like new. and its one of the quietest filters also. you will still hear it, but not nearly as annoying as the other ones. the only problem with those filters is the mounting pipe is slippery (painted) so its a good idea to sand down the outer part that goes in the rubber coupler and wipe with alcohol. you wont see it anyway once installed. otherwise the filter may fall off.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Old 2 Weeks Ago   #3 (permalink)
Ironliftr3
New Member
Thanks Gearbox...your opinion is always valuable. So the install on a DX would be worthwhile?
Old 2 Weeks Ago   #4 (permalink)
gearbox
Super Moderator
usually dx is the best car for modding cause its much lighter and the engine always uses 16 valves (compared to ex which only uses 12 unless you are at full throttle, vtec). if you are modding for speed or gas mileage, dx is the best.
__________________
www.lubecontrol.com
Member 1025782
Old 2 Weeks Ago   #5 (permalink)
OCDjG
Member
OCDjG will become famous soon enough
Just know that replacing your stock air intake set up for a short ram one will not make a night & day difference when it comes to performance purposes. The greatest difference you'll get by doing this mod is a louder intake and that's about it. The HP gains, if any, are very minimal. That's why a lot of people usually say don't waste your time and money on such a mod unless you plan on changing out the headers and exhaust system as well.
What your goals performance wise for your car?
OCDjG is offline   Reply With Quote
Old 2 Weeks Ago   #6 (permalink)
Ironliftr3
New Member
Not really expecting a day an night difference, but I'd like to do whatever I can to get a little 'boost' out of the engine, without spending a fortune.
What I'd really like is a little more low end 'quickness' rather than over all top end speed. The vast majority of my driving is done under 60 mph.
Again, not looking to spend a fortune, nor degrade the reliability of the vehicle. Always open to suggestions!
Old 2 Weeks Ago   #7 (permalink)
gearbox
Super Moderator
i like my weapon-r, compared to the 4 other intakes ive tried (aem, K&N, etc) the weapon-r performs best at lower rpms and about the same in higher rpms. i do most of my driving around 3-4k rpms to save gas. and its the quietest intake but still makes noise.
__________________
www.lubecontrol.com
Member 1025782
Tags
2000 , 2005 , 2006 , 98 , air , car , civic , clean , dx , filter , forums , gas , honda , images , intake , mileage , vtec
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
My new 4th gen hatch
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Shifting problem, won't go into gear
Power Window issues on my 96 EX
96-00 ex rear disc conversion?
Turbo Kit for D16Y8 (44K miles)
Tire Size
Lets Get some Pics of Older Civics in Here
Site Supporters
aluminum radiator
Honda car spoilers
