Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 2 Weeks Ago   #1 (permalink)
Tegetus
New Member
Tegetus is an unknown quantity at this point
Runs rough in 1st and 2nd then fine after that
Hello all,
97 civic with manual and 4 banger. I'm helping a friend out. His civic runs rough and has no power in 1st and 2nd, but then is fine for the other three gears. Code came up as a multiple cylinder misfire. I'm going to work on it this weekend hopefully. Anyone run into anything similar? I'm thinking vaccum lines, but would that affect a manual tranny? If it was fuel, intake or exhaust, it would just suck across the board. Let me know your thoughts....
Tegetus is offline   Reply With Quote
Sponsored Links
Old 2 Weeks Ago   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: Runs rough in 1st and 2nd then fine after that
misfires are usually caused by fuel delivery issues (like clogged injectors), bad or incorrect spark plugs, or faulty/cheap ignition system components like cap/rotor/wires. make sure you are using quality parts. last resort is blown headgasket from coolant leaking on the plugs and causing the misfires.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Old 2 Weeks Ago   #3 (permalink)
Tegetus
New Member
I agree, but the only thing is that the motor runs just fine in 3rd 4th and 5th gear. If it were any of the problems that you listed, then there would be issues across the board. The misfire code probably has been thrown by something else. Is there some type of vaccum line that is affected by what gear that you are in on a manual tranny?
Old 2 Weeks Ago   #4 (permalink)
gearbox
Super Moderator
vacuum issues are possible if there a small leak. i would check for cracking esp the ones near the throttle body.
__________________
www.lubecontrol.com
Member 1025782
Tags
01 , 2000 , 2001 , 2009 , bodies , civic , honda , misfire , motor , multiple , rough , running , runs , shifts , startup , stop , throttle
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
My new 4th gen hatch
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Shifting problem, won't go into gear
Power Window issues on my 96 EX
96-00 ex rear disc conversion?
Turbo Kit for D16Y8 (44K miles)
Tire Size
Lets Get some Pics of Older Civics in Here
Site Supporters
aluminum radiator
Honda car spoilers
