Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 3 Weeks Ago   #1 (permalink)
Ironliftr3
New Member
Ironliftr3 is an unknown quantity at this point
Broken Bolt
Replacing my front brakes yesterday with new Hawk pads. No big deal, should take a couple hours at most. Everything came apart fine, rotors are in good shape. Passenger side goes together fine. Using a torque wrench to tighten the last bolt to fasten the caliper, with the wrench set to 40ft-lbs, I swear that mofo NEVER clicked, and the damn bolt snapped off.
Break out the drill and extractor, and the EXTRACTOR breaks in the bolt. WTF!?!
That extractor is hard as HELL, and drilling it isn't doing a damn thing other than making a small indentation. I don't have any welding equipment. What are my options? Going to try to drill it out again, but I guess otherwise I'm looking at replacing the entire caliper assembly?
Nothing is ever easy! Even the seemingly simple jobs seem to turn into a nightmare...no pun intended, considering it was Halloween.
Ironliftr3 is offline   Reply With Quote
Sponsored Links
Old 3 Weeks Ago   #2 (permalink)
Ironliftr3
New Member
Re: Broken Bolt
Luckily, the Auto Warehouse had a brake front caliper assembly for $20. Now I'm pissed I spent so much time and energy trying to drill the damn thing out in the first place! Replaced the caliper bracket and all is well.
Old 2 Weeks Ago   #3 (permalink)
marek91
New Member
marek91 is an unknown quantity at this point
Re: Broken Bolt
wow good to hear =) hope that doesnt happen to me today replacing my rotors and pads
marek91 is offline   Reply With Quote
Old 2 Weeks Ago   #4 (permalink)
Ironliftr3
New Member
Re: Broken Bolt
SOMEDAY I'll have to figure out a way to extract a broken bolt that actually WORKS. Had this not been an easily replaceable part, I don't know what I would have done. I'd probably still be drilling and breaking bits.
I actually figured out WHY the bolt broke in the first place, although I hate to admit it. Newbie mistake that I'm SURE I'm not the first to have made, and I'll be sure to never make again.
Old 2 Weeks Ago   #5 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: Broken Bolt
did you tighten instead of loosen?
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 2 Weeks Ago   #6 (permalink)
Ironliftr3
New Member
Re: Broken Bolt
Ha ha...Fortunately, I'm not THAT new!! No, it was a misreading of torque requirements and parts description in the Haynes manual. I was reading the specs for the wrong part. That coupled with having no idea just HOW tight 40lbs is compared to 20lbs of torque (with my JUST purchased torque wrench) led to disaster. Next time I'll know that when something says over 30 lbs, to check the spec twice. I got lucky this time with an easily replaceable part!
Old 2 Weeks Ago   #7 (permalink)
04 Honda Civic
Super Member
04 Honda Civic will become famous soon enough 04 Honda Civic will become famous soon enough
Re: Broken Bolt
Slide pins don't get very tight, next time you can try a machine shop to remove the broken bolt. Maybe for a decent price they can do it.
04 Honda Civic is online now   Reply With Quote
Tags
bolt , bolts , brake , broke , broken , caliper , civic , extractor , honda , kit , machine , picture , remove , replace , shop
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
My new 4th gen hatch
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Shifting problem, won't go into gear
Power Window issues on my 96 EX
96-00 ex rear disc conversion?
Turbo Kit for D16Y8 (44K miles)
Tire Size
Lets Get some Pics of Older Civics in Here
Site Supporters
aluminum radiator
Honda car spoilers
