Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 4 Weeks Ago   #1 (permalink)
19Civic96
New Member
19Civic96 is an unknown quantity at this point
How to Determine Engine.
Hi i bought what i thought was a 1996 civic ex, But when i met with the guy he said he had put a 1998 civic engine in it due to a crack in the block. and it has a very play cylinder head. gray with honda on it. Someone told me that a ex civic had to be replaced with another ex engine. He also said that EX civics where VTEC's. I was wondering how to tell if it is a VTEC. And should i N/A tune it seeing as im a moderate tuner? To remove this ad, register today for free or log in if already registered!
19Civic96 is offline   Reply With Quote
Sponsored Links
Old 4 Weeks Ago   #2 (permalink)
ScottDR
Member
ScottDR will become famous soon enough
Re: How to Determine Engine.
I'm not understanding what you are all saying, but there is a stamp at the front of the block (next to the transmission) that has the engine code displayed. Find that code and you will know what engine was swapped in and no it didn't have to be a VTEC engine.
ScottDR is offline   Reply With Quote
Old 4 Weeks Ago   #3 (permalink)
CraigW
Platinum Member
CraigW's Avatar
CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light
Also look on the timing cover for a white sticker that has the code printed on it.
CraigW is offline   Reply With Quote
Old 4 Weeks Ago   #4 (permalink)
ScottDR
Member
Have you found the engine code? It should be D16y8 (for stock SOHC VTEC 96-00).
Old 4 Weeks Ago   #5 (permalink)
Awjvail
Member
Awjvail is an unknown quantity at this point
You can post a picture up here if you can't find any codes.. somebody should be able to identify it...
Awjvail is offline   Reply With Quote
Old 4 Weeks Ago   #6 (permalink)
19Civic96
New Member
I will try i will by swapping an engine into it and i just wanted to see what it was so i could possibly sell it later. Um, Is there anyone that has done a 1996 Ex swap to a h22a in this forum?
Old 3 Weeks Ago   #7 (permalink)
98sLicKvIc
New Member
98sLicKvIc's Avatar
98sLicKvIc is an unknown quantity at this point
the best spot to go for swap info is hondatech.com.
good luck bro
98sLicKvIc is offline   Reply With Quote
Old 3 Weeks Ago   #8 (permalink)
98sLicKvIc
New Member
98sLicKvIc's Avatar
good luck bro
Tags
6th , 96 , civic , determine , engine , forums , gen , generation , honda , identify , motor , sixth , tune , type , vtec
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
My new 4th gen hatch
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Shifting problem, won't go into gear
Power Window issues on my 96 EX
96-00 ex rear disc conversion?
Turbo Kit for D16Y8 (44K miles)
Tire Size
Lets Get some Pics of Older Civics in Here
Site Supporters
aluminum radiator
Honda car spoilers
