Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 10-10-2009   #1 (permalink)
skrieck
New Member
skrieck is an unknown quantity at this point
1999 EX lacks power/acceleration
Recently acquired 1999 EX. w/90k miles. Seems pretty underpowered. Performed tune-up (definitely needed plugs and timing adjustment, repl. distr. cap, rotor, & fuel filter, air filter clean) with surprisingly little effect. Compression check: 190, 191, 197, 201; ran a tank of fuel with system/injector cleaner, and a couple of tanks of premium - no effect; ran a couple of doses of sea-foam through vacuum port into combustion chamber, with very slight improvement in performance. Post-sea-foam compression check 200, 201, 200, 205. Vacuum check was spot-on with factory specs.
Brought to dealer - they spent a day and couldn't find anything wrong; checked cam timing; checked for exhaust blockage found none; interestingly, they said the air intake set-up wasn't exactly right (the car had been in a fender bender and apparently resulted in part of the plastic intake duct being partly obstructed, which I hadn't noticed) which they rectified. They ended up saying they thought nothing was really wrong with the car (!!??) When I got the car back from them, it did have a bit more power, small amount but noticeable going up hills (air-intake result?). Still, when I press accelerator gradually there is very little response and I just keep pressing and pressing until finally the trans downshifts and I'm revving 4000-5000 rpm and finally accelerating. My mother's 2000 LX w/50k more miles, and my sister's 1998 LX w/35k more miles have noticeably better acceleration in comparison.
Any ideas about what might be the issue here??
skrieck is offline   Reply With Quote
Sponsored Links
Old 10-10-2009   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: 1999 EX lacks power/acceleration
have you tried cleaning the intake system? throttle body, idle valves, etc. they tend to get gummed up with carbon. you sure the ignition timing is good? and be sure to use 87 octane for the most power. its also possible you have a clogged cat converter, not enough to cause problems yet, but blocking some airflow so the engine feels stuffed.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 10-10-2009   #3 (permalink)
skrieck
New Member
Thanks for the notes.
The sea-foam through the vacuum port should have addressed any carbon in the combustion chamber, and it is fuel-injected. I did not perform the first sea-foam treatment, but the mechanic who did assured me that there was a decent amount of carbon cleaned out; I performed the 2nd treatment with almost no additional results, so I assume it is pretty clean in there. The mechanic at dealership assured me he checked for exhaust/cc blockage (probably blow-back test) and there was none. I set the timing to factory spec, and I'm assuming the dealer probably just double-checked it to be sure.
Thanks,
Skrieck
Old 10-10-2009   #4 (permalink)
gearbox
Super Moderator
did you get the engine valve lash adjusted? they may be too loose and that will cause power loss. usually every 100k they need adjusting but sometimes sooner depending on driving habits.
__________________
www.lubecontrol.com
Member 1025782
Old 10-11-2009   #5 (permalink)
skrieck
New Member
I'm not hearing any valve tappet sounds, which I think would be quite audible if the adjustment were so loose as to actually cause power loss. I've never had an engine with an overhead cam though, so maybe valve sounds or lack thereof is different for this kind of setup - easy enough to check the lash though.
Thanks for the suggestion.
Oh, and it just occurred to me that if there were lash issues, then I probably wouldn't have gotten such good compression readings. The compression readings were quite good. (184 being "normal", mine are around 200)
Old 10-11-2009   #6 (permalink)
gearbox
Super Moderator
well if its that high, usually means there is carbon buildup on the pistons. which i guess is a good thing since it raises compression. not really sure what else you can check. just be sure all the parts you use are good quality like ngk plugs and wires not cheap generic stuff.
__________________
www.lubecontrol.com
Member 1025782
Tags
1999 , 2000 , acceleration , adjustment , body , cars , civic , clogged , forums , honda , lacks , loss , lx , power , throttle , timing , tune
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
My new 4th gen hatch
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Shifting problem, won't go into gear
Power Window issues on my 96 EX
96-00 ex rear disc conversion?
Turbo Kit for D16Y8 (44K miles)
Tire Size
Lets Get some Pics of Older Civics in Here
Site Supporters
aluminum radiator
Honda car spoilers
