Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 10-06-2009   #1 (permalink)
ether.real
New Member
ether.real is an unknown quantity at this point
Transmission Bearing Noise?
Hello all, looking for advice on my 1996 Civic DX hatchback. It has a 5 speed manual transmission, with 152k miles.
I am concerned about what sounds like a bearing, here are the symptoms:
-grinds when the car is in neutral, with the clutch out. Goes away when I press the clutch in.
-I cant hear it when the car is moving.
-worse when its cold, and at first start. Quiets down if the car is warmed up for a while.
-Everything shifts fine.
I have heard that this can be due to the throwout bearing, however this bearing got replaced when I had the clutch replaced, and the sound did not go away. Another suggestion is the Input Shaft Bearing.
I realize that I might as well replace the tranny instead of the bearing, however, what I am curious about is, what happens if I keep driving on it? Does it slowly get worse until it breaks, or does it carry a risk of catastrophic damage?
Thanks in advance,
ether
ether.real is offline   Reply With Quote
Sponsored Links
Old 1 Week Ago   #2 (permalink)
Cleft_Asunder
Super Member
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light
Re: Transmission Bearing Noise?
I've got exactly the same problem. I replaced my input shaft bearing, but it didn't fix the problem. In fact, the old one was just fine. There are two bearing on the input shaft, and I think the large one is the problem --the one that I shrugged off for some reason.
__________________
'97 Civic DX 5-speed: Keyed to perfection.
http://www.civicforums.com/forums/signaturepics/sigpic34179_1.gif
Updated 96-00 timing belt DIY
Cleft recommends Raxles axles
Research the New World Order
Cleft_Asunder is offline   Reply With Quote
Old 1 Week Ago   #3 (permalink)
ScottDR
Member
ScottDR will become famous soon enough
Sounds like you got your answer on the problem. Just curious, did you change the MTF according to the maintenance schedule? And did you use Honda MTF?
On the question of failure...well, I'd just replace those bearings sooner rather than later so they are still fixable. By waiting you most likely will cause more damage and why toss away a good transmission if that's the only problem? They are simple to work on with the factory manual.
ScottDR is offline   Reply With Quote
Tags
2000 , 2001 , 2005 , 2007 , bearing , bearings , civic , honda , input , manual , noise , photos , problems , si , transmission
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
My new 4th gen hatch
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Shifting problem, won't go into gear
Power Window issues on my 96 EX
96-00 ex rear disc conversion?
Turbo Kit for D16Y8 (44K miles)
Tire Size
Lets Get some Pics of Older Civics in Here
Site Supporters
aluminum radiator
Honda car spoilers
