Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 10-05-2009   #1 (permalink)
lebstyle007
New Member
lebstyle007 is an unknown quantity at this point
headlight problem
Hi I have a 1997 Honda civic, has a wierd problem.
I changed the daytime running light module, but still have the same problem.
When you turn the car on the left headlight is very bright, and the right one is very very weak light, you can barely see it on.
When you turn the headlights on they work normally.
I tested the voltage at the headlights, when the daytime running lights are on, the right one reads 8.5 volts, the left one is at 14 volts, but it is very bright, seems like both the high beam and low beam are on.
Now another thing is when you remove the fuse for the left side headlight, there is still power going to it in daytime running mode, so when you remove the fuse the light lights up like a normal daytime running light.
and when you unplug the right side plug from the bulb, the left side lights up normally like a daytime running light should. but as soon as u plug it back in the left one lights up very bright.
now either there is a power draw at the left side, or a problem with the right side, or a problem with the daytime running light system, I changed the module a few times so far, I interchanged it from a 2001 civic, which looks the same and same plug.
Also at the fuse box everything is normal when the headlights are on, but when I turn them off (daytime running mode) the right side has no voltage there, and the left side has 8.5 volts.
Is there anything I should be changing?
Thanks in advance.
lebstyle007 is offline   Reply With Quote
Sponsored Links
Old 10-05-2009   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: headlight problem
sounds like a bad ground wire for the headlight harness. usually they are grounded under the bumper and they get corroded.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Tags
00 , 1997 , 2005 , 97 , changing , civic , ground , harness , headlamp , headlight , headlights , honda , remove , removing , wire
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
My new 4th gen hatch
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Shifting problem, won't go into gear
Power Window issues on my 96 EX
96-00 ex rear disc conversion?
Turbo Kit for D16Y8 (44K miles)
Tire Size
Lets Get some Pics of Older Civics in Here
Site Supporters
aluminum radiator
Honda car spoilers
