Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 2 Weeks Ago   #16 (permalink)
DeX
Canadian, Eh!
DeX's Avatar
DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all
Re: Engine quits while driving
Quote:
Originally Posted by cueist63 View Post
My mechanic found that my distributer and cap were defective, he replaced them and put on new ignition wires last Friday, so far so good.
Same problem with my ex girlfriend's car over the weekend. She called me when it happened and I thought fuel delivery as well. Then she brought it to a shop the next day and he said it's the distributor.
Check your timing to see if something got adjusted there while fooling with the distributor. Also turn the key to ACC and see if you can hear the fuel pump coming on. If not that it could also be the fuel pump relay.
__________________
7th Generation Member Against Street Racing Number 43
www.em2ab.com
Fully integrated carputer with W-Fi, GPS, 2000 songs/music videos, and weather
7 inch Xenarc 700TSV VGA in dash touchscreen
Compustar 2 way paging alarm/starter system
35% tint excluding windshield
D.I.Y. Blacked Out Headlights
D.I.Y. Debadge
D.I.Y. Remote Trunk Release
D.I.Y. Trunk Air Shocks (Scouting Parts)
Air Ride Suspension Setup (Awaiting Parts)
DeX is offline   Reply With Quote
Sponsored Links
Old 2 Weeks Ago   #17 (permalink)
cueist63
New Member
cueist63 is an unknown quantity at this point
I called the honda dealer yesterday and there is a recall on my ignition switch, goes in today to be replaced. The one I bought on ebay didn't fit.
cueist63 is offline   Reply With Quote
Old 2 Weeks Ago   #18 (permalink)
DeX
Canadian, Eh!
DeX's Avatar
Can you explain it in more detail exactly what the problem is?
__________________
www.em2ab.com
D.I.Y. Debadge
Old 2 Weeks Ago   #19 (permalink)
slow hatch
New Member
slow hatch is an unknown quantity at this point
I had the same prob and it got more frequent till i took my ign switch out and you can seperate the two pieces and find the contact point corrode i sanded them down a little and it worked for a few months then started again. sure enough took it apart and it was worn down to nothin so took one out of another honda at the junk yard and has been fine for the last 8 months.
slow hatch is offline   Reply With Quote
Old 2 Weeks Ago   #20 (permalink)
ssclayton10
New Member
ssclayton10's Avatar
ssclayton10 is an unknown quantity at this point
well according to the recall that guy posted about the electrial problem i mean if you have too many watts flowing through your ignition switch it sounds like to me its nothing that a simple relay cant fix. but idk.
ssclayton10 is offline   Reply With Quote
Old 2 Weeks Ago   #21 (permalink)
cueist63
New Member
Looks like problem solved. Called Honda dealer and there was a recall on my
ignition switch. Had it replace at dealer for free on Tuesday, been fine since.
Thanks for all the help.
Old 2 Weeks Ago   #22 (permalink)
cRaZyTrOy48
New Member
cRaZyTrOy48 is an unknown quantity at this point
i have the same exact problem it only happens to me either wen its too cool outside or wen it has low gas my car is automatic it only turns off wen the rpm's go down to 1 i did a diagnostic and found out i have throttle malfunctions and bad oxygen sensors if that helps..
cRaZyTrOy48 is offline   Reply With Quote
Tags
1996 , 2007 , 98 , cam , car , civic , cuts , cutting , driving , engine , gear , honda , power , quits , sensor , stalled , wont
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
My new 4th gen hatch
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Shifting problem, won't go into gear
Power Window issues on my 96 EX
96-00 ex rear disc conversion?
Turbo Kit for D16Y8 (44K miles)
Tire Size
Lets Get some Pics of Older Civics in Here
Site Supporters
aluminum radiator
Honda car spoilers
