Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 10-01-2009   #1 (permalink)
Evans96
New Member
Evans96 is an unknown quantity at this point
Old Faithful Needs Attention
Hello, new to the forum here and my goal is to keep my car running forever. I have a 1996 EX 5spd coupe (all stock). It is only my 2nd car ever and Its been my daily driver since 1999 when i bought it with 20,500 miles. I am totally attached to it and will not part with it until it is not worth fixing. It has been through alot and been hit on 3 out of 4 sides by random idiots that dont know how to drive
This may sound unbelievable but it has 242,000 miles with the ORIGINAL CLUTCH!! It also has the ORIGINAL DRUM BRAKES!! Im new to the forum, but is this as uncommon as I think it is?
The only things I've done to it: 1. regular oil changes
2. 3 tune-ups
3. 3rd exhaust (should have got stainless)
4. 3rd slave cylinder
5. CV boot ripped and repaired
6. new radiator
7. couple front brake jobs w/rotors
The problem, if you want to call it that, is that it also has the ORIGINAL TIMING BELT!!
I have a Haynes manual that Ive used to do everything so far, but the timing belt replacement looks complicated. Can anyone tell me about how bad it actually is or lead me in the right direction? The car runs fine but I don't want the timing belt to snap its time to do it.
Evans96 is offline   Reply With Quote
Sponsored Links
Old 10-01-2009   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: Old Faithful Needs Attention
yeah if you are not comfortable, i advise going to a good shop. just be sure to use the honda coolant and honda parts. its a pretty big job that you dont wanna mess up.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 10-01-2009   #3 (permalink)
hb pickup
New Member
hb pickup is an unknown quantity at this point
Hey Evan, U just reminded me mine's about due again. Dang your car's been good to U! Mine's had the speedo go out (pretty much) @118k, & the heater core puked up a couple years ago & now the CEL's on for a catconv. For the timing belt chg that bigass nut-shaped holding tool for turning the crank pulley was a must-have. Worked best for me on a long extension thru the inside fender hole all the way to the outside of the body with a bigass ratchet (but I'm weak). Make sure you got all the pulleys lined up for #1TDC before pulling the belt & recheck after installing and after tensioning too. Before putting the valve cover back on check your valve clearance. Clean up the head & valve cover real well where the gasket seats, especially the corners where it curves over the cam, and use a noncorrosive RTV for no leaks. I'd replace the gasket @ the mileage U got too.
hb pickup is offline   Reply With Quote
Old 10-07-2009   #4 (permalink)
sql_civic
Super Member
sql_civic's Avatar
sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light
I would change that TB ASAP. I had one break on me after 90,000 miles luckily with no adverse affects. I don't think that changing a TB is that hard at all on a SOHC. But if you're only experienced at doing oil changes and spark plugs you best have someone else do it. Often local garages or dealers have specials.
sql_civic is offline   Reply With Quote
Old 10-07-2009   #5 (permalink)
OCDjG
Member
OCDjG will become famous soon enough
Dude you're playing with fire here. The TB & water pump replacement is the single biggest maintenance item that you need to worry about at 100k. From my understanding of it, its not all that simple. Go to a trusted mechanic and have them do this service for you. It should run you between $400-$600 for the entire job including parts.
OCDjG is offline   Reply With Quote
Tags
6th , belt , change , civic , drums , forums , gen , honda , manual , timing
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
My new 4th gen hatch
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Shifting problem, won't go into gear
Power Window issues on my 96 EX
96-00 ex rear disc conversion?
Turbo Kit for D16Y8 (44K miles)
Tire Size
Lets Get some Pics of Older Civics in Here
Site Supporters
aluminum radiator
Honda car spoilers
