Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-29-2009   #1 (permalink)
omalley808
New Member
omalley808 is an unknown quantity at this point
96 JDM type-r bogging badly HELP!
As the title states I have a 96 spec JDM ITR complete swap in my 00 civic EM1. The car has the obd2b to obd2a conversion harness with the matching p73 ecu. There are no check engine lights but the car has a terrible bog in the low range rpm.
It seem like you can floor the car in any gear and if the rpm is below 4 grand the car has absolutely no power. I have mini vans passing me! The car pulls strong and hard in vtec though but it seems like I have to rev the hell out of it to get any power at all!
Im getting terrible fuel mileage as well! I have swapped FPR, ECT, plugs, wires, distributors, tps, IAT, map sensor, new fuel filter, swapped fuel pump, O2 sensor, no luck! I also did a valve adjustment too!
One clue is the car seems to have trouble starting also. It takes an extra half crank to start the car and it stumbles then clears! I have a fuel pressure gauge on the car and the fuel pressure drops from about 35-40psi zero after about 10minutes.... is this normal? I also hear a strange noise coming from the gas tank....? If i remove the vent to tank from the black charcoal canister the sound is very audible with the car not running it is makes a strange noise for about 3 seconds then goes away?
One more thing to mention is when swapping different things i tried my buddies FPR off his GSR and when i pulled the return line hose from his FPR it was full of fuel even though his car had been sitting for at least a month! Mine on the other hand was bone dry? Is it possible there is a problem with my Fuel return?
I have literally tried everything except swap the injectors! This thing is making me crazy!
Any help would be more than greatly appreciated!
omalley808 is offline   Reply With Quote
Sponsored Links
Old 09-30-2009   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: 96 JDM type-r bogging badly HELP!
its very possible a fuel problem from what you describe. you may have clogged injectors or something clogged in the lines (or fuel filter needs replacement). have you cleaned out all the intake parts like idle and fitv valves and throttle body?
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Old 09-30-2009   #3 (permalink)
omalley808
New Member
Yes sir I put a brand new OEM honda fuel filter and I cleaned the TB with throttle body cleaner, cleaned the IACV and I even seafoamed the engine. Tried running fuel injector cleaner also with no luck....
Should my car be keeping fuel pressure even after turning it off? Because it bleeds to 0 after about 10minutes....Also the fuel return line not having any fuel in it seems a bit suspicious....
Old 09-30-2009   #4 (permalink)
gearbox
Super Moderator
it should yes. and all lines need to have fuel. thats prolly the issue you have with the car not starting right away (like vapor lock). do you have any leaks? is the gas cap good?
__________________
www.lubecontrol.com
Member 1025782
Old 09-30-2009   #5 (permalink)
omalley808
New Member
There are no fuel leaks...The gas cap has been replaced with an aftermarket one...Another strange comment I will make is when im filling the gas tank at the station it sounds like the air has nowhere to go...As if when I fill the gas tank with gasoline the air is rushing back up the line and around the pump nozzle? Hard to explain but its like you can hear air coming back out of the tank when you are filling with gasoline....Doesnt make this noise when I fill my s2000 or any other car....
Old 09-30-2009   #6 (permalink)
gearbox
Super Moderator
yeah something is wrong with the fuel system. and its really hard to figure out without taking stuff apart.
__________________
www.lubecontrol.com
Member 1025782
Old 09-30-2009   #7 (permalink)
omalley808
New Member
Where do I start? One thing that came to my mind was the fact that I believe on this car there is an EVAP unit beside the gas tank under the car. My JDM ECU is essentially a OBD1 ecu so it no longer uses any of the emissions stuff...Is it possible there is some sort of electronic valve in that unit that isnt opening?
Old 09-30-2009   #8 (permalink)
gearbox
Super Moderator
yeah its possible. the evap system has alot of valves and solenoids. the system is actually quite complicated and uses hoses and valves to direct gas vapors back to the engine from the gas tank. and its on a cycle so ecu needs to open the valve for it to work. you really need to get a manual and see how the system is setup. im not sure what you can do tho unless you figure out how to disable the system.
__________________
www.lubecontrol.com
Member 1025782
Old 10-05-2009   #9 (permalink)
omalley808
New Member
NEW UPDATE: Still having the problem...Tried running the car with the IACV unplugged from the ECU and the car obviously wont idle...But if I try to hold a steady rpm for example 3000 it will bounce up and down and you cant even drive the car partial throttle. Does this give us any more ideas as to what is wrong? Because even with the IACV plugged in the car is hard to drive in traffic and is very jerky. But with it unplugged the problem is amplified???
Tags
96 , bogging , change , civic , dx , em1 , filter , fuel , honda , jdm , low , part , pics , rpms , throttle , type
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
My new 4th gen hatch
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Shifting problem, won't go into gear
Power Window issues on my 96 EX
96-00 ex rear disc conversion?
Turbo Kit for D16Y8 (44K miles)
Tire Size
Lets Get some Pics of Older Civics in Here
Site Supporters
aluminum radiator
Honda car spoilers
