Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-15-2009   #1 (permalink)
jako
New Member
jako is an unknown quantity at this point
Seized cam
My son's 96' EX had the cam seize, and the gear spun on the cam.
I'm gonna pull the cam out tomorrow to see if it can be reused.
I know that Honda calls this an interference motor, but I also hear that it may not be.
Might I get away with new bearings and a cam polish up?
I suspect that the car was driven for several weeks after the gear started to
spin, so I doubt the valves would have been spared impact with the pistons if this is indeed an interference engine.
jako is offline   Reply With Quote
Sponsored Links
Old 09-16-2009   #2 (permalink)
rednwhite04
Senior Member
rednwhite04 will become famous soon enough
Re: Seized cam
If the gear moved on the cam your gonna need a new one. period.
rednwhite04 is offline   Reply With Quote
Old 09-16-2009   #3 (permalink)
jako
New Member
Re: Seized cam
A new what?... cam?
I got a new gear, that end of the cam is o.k. as the old gear failed before the much harder cam.
Old 09-16-2009   #4 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
Re: Seized cam
Honda's are interference motors. Check your valves before throwing things back together and trying to run the car.
Honda heads do not use cam bearings either, they simply use journals machined into the head and rocker arm assembly. The cam itself is probably fine and so are the pistons, but I'll bet dollars to donuts that some of the valves are not.
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Old 09-16-2009   #5 (permalink)
jako
New Member
Re: Seized cam
It sounds as if I'll need a replacement head, assuming that the aluminum journals have galled, and valves are bent.
Would it make sense to pull the rocker shafts and do a compression test to check for bent valves?
Old 09-16-2009   #6 (permalink)
speedfoos
speedfoos's Avatar
Re: Seized cam
You can do that if you like. It takes a lot to mess up those journals and it's usual a low-oil situation that causes them to get messed up.
If the gear spun, there's a good chance the keyway on the end of the cam is now a circular groove instead of a keyway anymore. Check that first. If that is bad, you now a cam to source or get repaired, new cam gear, possible journal damage, possible/probable bent valves, etc... It would be much cheaper to just pick up a used D16Y8 cylinder head and swap it completely out and be done with it. That way you're only into it for around $100 for the head and $40 in gaskets.
__________________
www.7thgenhonda.com
Old 09-16-2009   #7 (permalink)
speedfoos
speedfoos's Avatar
Re: Seized cam
Here you go. Complete Y8 for $110 shipped.
Ebay D16Y8 used head
__________________
www.7thgenhonda.com
Old 09-16-2009   #8 (permalink)
jako
New Member
Re: Seized cam
You got that right, I just pulled the cam. The galling was so bad that the cam is junk! The bearing surface closest to the gear is DEEPLY grooved.
A new head it is.
Thanks for the help AND the link!
Old 09-16-2009   #9 (permalink)
speedfoos
speedfoos's Avatar
Re: Seized cam
No probs, glad to help.
__________________
www.7thgenhonda.com
Tags
2000 , 2007 , bent , cam , camshaft , civic , engine , galling , honda , seized , test , valves
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
My new 4th gen hatch
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Shifting problem, won't go into gear
Power Window issues on my 96 EX
96-00 ex rear disc conversion?
Turbo Kit for D16Y8 (44K miles)
Tire Size
Lets Get some Pics of Older Civics in Here
Site Supporters
aluminum radiator
Honda car spoilers
