Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-13-2009   #1 (permalink)
BurtReynolds
New Member
BurtReynolds is an unknown quantity at this point
Trouble starting 2000 EX
I have a 2000 EX, auto, with a stock motor with 124k on it and after returning from a week long vacation, my car didn't want to turn over. Its hard to describe the sound it made, but it would crank and just couldn't turn over. I eventually hit the gas while cranking it, and I got it to start, it ran rough at first, but I took it for a trip around the block after idling in the garage for a few and it seemed okay. I did notice some coolant (like a few drops, nothing big) leaked out while I had the car running in the garage, which I've never noticed before. I started it a couple more times yesterday and it was normal. I just started it this morning and it was running a bit rough at idle, but turned over right away.
I had most of the ignition system replaced last year, so I don't think that could be the problem. Up until yesterday, I didn't really have any issues with starting.
I am just wondering if there are some areas that could cause this problem. I need to replace my tires and brakes, so if I possibly have some lurking major issue, I might just get rid of it. I had the timing belt, tensioner, drive belts, and valve cover gasket replaced about 5-6 months ago. If I didn't have a 100 mile commute everyday, I wouldn't be so concerned about it.
Thanks for your input.
BurtReynolds is offline   Reply With Quote
Sponsored Links
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
My new 4th gen hatch
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Shifting problem, won't go into gear
Power Window issues on my 96 EX
96-00 ex rear disc conversion?
Turbo Kit for D16Y8 (44K miles)
Tire Size
Lets Get some Pics of Older Civics in Here
Site Supporters
aluminum radiator
Honda car spoilers
