Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-07-2009   #1 (permalink)
jumbot
New Member
jumbot is an unknown quantity at this point
Smile 96 Civic Si Oil Problem?
Hello, I got a 96 civic si. that i got off my buddy... i noticed that lately its been leaving small (i believe oil) spot in my drive way. Its about the size of a quater (ever night). I check my oil level, and it seems half way full even tho i changed the oil 3 days ago. I am interested if this should set off alarms and i should dump this car and get a new one, or this is manageble for a while at least a winter. The car does have a leak just before the catalytic converter. Could that be where the fluid is coming from? But honestly the car drives great, no problems with it, dosen't smoke anywhere, great on gas. Just trying to figure out if this should be a concern. Maybe i should put in some lucos product? what do you guys think?
Thank you
jumbot is offline   Reply With Quote
Sponsored Links
Old 09-07-2009   #2 (permalink)
ProVic
New Member
ProVic is an unknown quantity at this point
Re: 96 Civic Si Oil Problem?
i have the same problem
show us a picture where it leaks
ProVic is offline   Reply With Quote
Old 09-07-2009   #3 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
could be coming from anywhere, oil pan seal, other engine gaskets, timing belt area, etc.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 09-07-2009   #4 (permalink)
jumbot
New Member
ill try to get you guys a pic as soon as i can, kinda hard with out getting the car up in the air. But does that leak have anything to do wiht me losing oil? my mechanic said i need to get a new cat pipe and muffler anyways to pass emissions this year. said its about $400 CAN, sound about right?
Old 09-07-2009   #5 (permalink)
gearbox
Super Moderator
well if its an oil leak then yes
__________________
www.lubecontrol.com
Member 1025782
Old 09-08-2009   #6 (permalink)
04 Honda Civic
Super Member
04 Honda Civic will become famous soon enough 04 Honda Civic will become famous soon enough
If your losing oil and there is oil on the ground after u park I believe u have an oil leak lmao..Now you just need to find it, make sure u top off every day or so with oil or you will destroy the motor.
04 Honda Civic is offline   Reply With Quote
Old 09-11-2009   #7 (permalink)
jumbot
New Member
Thanx guys for all of your help... i took the car in to a mechanic and he found the leak although i forgot where it was, he said it was not that bad and seen worse. So his advice is just to drive the car and the engine in to the ground instead of doing the timing belt right now, and he will jsut install for me an engine from japan that has like 50 000K on it wiht the timing belt at the same time. Sounds resonable for the money i would have to spend for the timing belt now, vs timing belt and a slightly used engine later.
But thanx for the advice guys.
Old 09-11-2009   #8 (permalink)
04 Honda Civic
Super Member
How much is he going to charge you for a new motor. I am almost 100% sure its not worth it. A tb and gasket wont cost you more then $1000 actually it would be around $600ish depending on the gasket a new motor is probably gunna run u at least $1500 or better
Tags
00 , 2001 , 6th , 96 , 98 , car , catalytic , civic , generation , honda , leak , leaking , oil , pan , si
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
My new 4th gen hatch
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Shifting problem, won't go into gear
Power Window issues on my 96 EX
96-00 ex rear disc conversion?
Turbo Kit for D16Y8 (44K miles)
Tire Size
Lets Get some Pics of Older Civics in Here
Site Supporters
aluminum radiator
Honda car spoilers
