Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 08-29-2009   #1 (permalink)
caseymx
New Member
caseymx is an unknown quantity at this point
2000 Civic will not start
I have a 2000 honda civic lx. I started the vehicle and attempted to leave the store and when I put the car in reverse and started backing, it sputtered and died. Now all it will do is spin over. Towed it home and found that I wasnt getting fire. After doing tests I came up with the conclusion that it was the ICM. Changed it and spark plugs and now I have spark and fuel but car will not attempt to start. It just spins over and doesnt even give a "pop". I was going to try and check timing but cant seem to find any marks on the crank pully. I do see the marks on the timing cover. When I do put the timing light on #1 and spin the car over, I'm not getting a light on any plug. But if I pull the plugs and plug them into the wire, I am getting fire and when I pulled the plugs they are wet with gasoline. So now I'm leaning towards timing. I'm getting fuel and spark and still no ignition. Not real experienced or a big fan of Hondas and not sure if I should be getting a timing light signal by just spinning the engine over on these cars.
Any suggestions?
caseymx is offline   Reply With Quote
Sponsored Links
Old 08-29-2009   #2 (permalink)
94honciv
New Member
94honciv is an unknown quantity at this point
Re: 2000 Civic will not start
Could be timing belt??? How many miles on it?
94honciv is offline   Reply With Quote
Old 08-30-2009   #3 (permalink)
caseymx
New Member
@ 130k. I looked inside the valve cover from the oil filler hole while I had someone spin it over, and the belt is definitely not broken but I'm worried it may have jumped. I also was doing some thinking last night and thought about how I couldnt get spark with the old worn plugs that were worn to almost .075 gap. The recomended is .044 gap. I had to close the gap on the old plug to almost .044 to get it to spark and it never was a nice blue spark, it was always a white kinda ball puff of spark. Then I thought about it, the plugs were firing on that much gap before I drove up at the store, now they wont fire nowhere near that much gap. I think I may have a weak fire issue. Changed the ICM yesterday, think I'm gonna change the coil today.
Tags
2000 , 2001 , 2005 , 2007 , civic , fire , hond , honda , plugs , si , spark , start , starting , time , wont
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
My new 4th gen hatch
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Shifting problem, won't go into gear
Power Window issues on my 96 EX
96-00 ex rear disc conversion?
Turbo Kit for D16Y8 (44K miles)
Tire Size
Lets Get some Pics of Older Civics in Here
Site Supporters
aluminum radiator
Honda car spoilers
