Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 08-09-2009   #1 (permalink)
98sLicKvIc
New Member
98sLicKvIc's Avatar
98sLicKvIc is an unknown quantity at this point
98 Civic Gauge Cluster problem
Hey guys. Very TEDIOUS problem.
1998 Civic EX D16y8 5spd
i tried driving my car tonight but when i powered it up and turned on my lights, my gauge cluster works but will not light up!!! i checked the under dash instrument fuse, and its fine. Headlights, tailights, and blinkers ALL WORK. i checked the dimmer switch and it isn't getting power though. I don't know if its relevant but i installed a new xplod deck today, but all i did was replace two fuses, and soldered the harness. i didn't touch anything else.
maybe i shorted something???
Any pointers or inquisitions are helpfull, i'm already tired of driving a five speed with a flashlight in one hand lol.
98sLicKvIc is offline   Reply With Quote
Sponsored Links
Old 08-09-2009   #2 (permalink)
bluetwo
New Member
bluetwo's Avatar
bluetwo is an unknown quantity at this point
Send a message via Yahoo to bluetwo
Re: 98 Civic Gauge Cluster problem
Well it's a new one on me too. My guess would be either a wire came loose or something got shorted. The best way to find out is to rip out the gauge cluster and inspect it to see if there is any obvious damage.
bluetwo is offline   Reply With Quote
Old 08-09-2009   #3 (permalink)
98sLicKvIc
New Member
98sLicKvIc's Avatar
i did that today. took apart everything. i have the haynes manual and it seems that everything that is not lighting up (gauge cluster, ac/heat console, dimmer switch) are all run along by a red/black wire. my SRS, brake lights etc. light up, but nothing will "illuminate" for night driving.
Old 08-09-2009   #4 (permalink)
bluetwo
New Member
bluetwo's Avatar
.....wierd. And you didn't see any scorched marks or melting?
I've had clusters apart my share of times but I can't think of anything else that comes into play here but just because I don't have any experience with this problem.
Replacing the fuses shouldn't have done anything to it. I guess you could try checking the bulbs next. I seem to remember having some kind of issues with burnt bulb interfering with other bulbs but honestly I'm shooting in the dark at this point. Good luck....
Old 08-11-2009   #5 (permalink)
98sLicKvIc
New Member
98sLicKvIc's Avatar
so i have tried all i can think of. but i am no master mechanic.
come on guys. i still have a gauge cluster and dash that doesn't illuminate.
i don't care if you know alot about cars or you're blowing smoke out your *** i need ideas!!!!
Old 09-08-2009   #6 (permalink)
DJ6ta
New Member
DJ6ta is an unknown quantity at this point
Going through the same thing and I am a Master Tech. Lol I'll let you know when I get this one figured out.
DJ6ta is offline   Reply With Quote
Old 09-24-2009   #7 (permalink)
xhaloz
New Member
xhaloz is an unknown quantity at this point
This happened to me once, it ended up being that if I wired my radio to the cable harness ground it turned out my dash lights, so I had to manually wire the ground to another location and not use the ground that comes on the radio harness. Hope this might help!
xhaloz is offline   Reply With Quote
Old 09-24-2009   #8 (permalink)
CraigW
Platinum Member
CraigW's Avatar
CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light
OP: If you made any connections to the "dimmer" or "illumination" wires for the headunit installation... I would take them loose or check that they are correct. Also what fuses did you replace ??
The dimmer control units seem to be known for problems on this generation Civic.
It is my understanding there is a box behind the actual dimmer control that houses the dimmer electronics.
CraigW is online now   Reply With Quote
Tags
6th , 96 , 98 , 99 , civic , cluster , fuse , gauge , generation , honda , instrument , light , lights , picture , replace
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
My new 4th gen hatch
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Shifting problem, won't go into gear
Power Window issues on my 96 EX
96-00 ex rear disc conversion?
Turbo Kit for D16Y8 (44K miles)
Tire Size
Lets Get some Pics of Older Civics in Here
Site Supporters
aluminum radiator
Honda car spoilers
