Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 08-06-2009   #1 (permalink)
Spiffy_B
New Member
Spiffy_B is an unknown quantity at this point
HID light problem, one light works.
I bought a HID kit awhile ago, installed it and everything went well for a few weeks. Then one night i saw that one of my lights were out. I looked under the hood an saw that made ballast hand fell from its spot.
I sent the ballast back, they sent me a slimmer one. Once i put that in, nothing happened, then i thought of a fuse. The fuse was blown, when I replaced that, nothing still. I bought new bulbs (went from 10k to 12k), still nothing. What am i missing? Does anybody have a clue to what I'm doing wrong or forgetting.
Spiffy_B is offline   Reply With Quote
Sponsored Links
Old 08-06-2009   #2 (permalink)
fracas
New Member
fracas is an unknown quantity at this point
Re: HID light problem, one light works.
check and see if you plugged them up.
fracas is offline   Reply With Quote
Old 08-07-2009   #3 (permalink)
Spiffy_B
New Member
Did that too, i did a complete re-install yesterday. I took the front bumper off, took out the headlights to do a headlight restoration. Shrink wrapped the connections and still nothing.
Old 08-07-2009   #4 (permalink)
fracas
New Member
Okay I would do this. Get a voltage meter and have someone turn the heallight switch on and off while you are checking the voltage on the headlight connector. You should have 1 negative, 1 positive for running lights for the blinkers, 1 positive for the headlights when they are on.
Now if you have 12v at the connectors like you should then its not the wiring. I would swap the working hid over to the side thats not working and try it out to see if the light works. If it does then you have a problem still with the Hid unit they sent you.
If you need a New Ballist and H4 Bulb I have one new in the box for $30. This isnt a full kit. I used one of them on my Gsxr. So the other is a extra.
Old 08-09-2009   #5 (permalink)
Spiffy_B
New Member
I was thinking of doing that, i found a volt meter at my job yesterday so ill do it today or tomorrow.
Thanks for the offer but i already bought a new ballast just for the crap of it. $22 and shipped from eBay. It should be here tomorrow. I hope something works out.
Thanks for the help Fracas.
Old 08-19-2009   #6 (permalink)
Spiffy_B
New Member
Ohk, I got a volt meter earlier and came to find out that I am getting power but think the ground isn't grounded so I'll be re-grounding it on Friday when I'm out. I rechecked the fuses and it was still fine.
Old 08-27-2009   #7 (permalink)
Spiffy_B
New Member
IT WORKED!!! I regrounded the negative wire with a 16 guage wire. It is a little bigger and the warranty replacement ballast didnt work still but the extra one i bought did work. I was able to see with one light but now will be even better, later tonight I'll post pics.
Tags
02 , 2002 , 6th , 98 , civic , fuses , gen , hid , honda , install , kit , kits , light , lights , problems , working
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
My new 4th gen hatch
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Shifting problem, won't go into gear
Power Window issues on my 96 EX
96-00 ex rear disc conversion?
Turbo Kit for D16Y8 (44K miles)
Tire Size
Lets Get some Pics of Older Civics in Here
Site Supporters
aluminum radiator
Honda car spoilers
