| Re: new alternator for a 97 civic? dont but an ebay one. and yes you need an alternator. I have a 300 watt RMS alpine 4 channel and a 1000watt RMS alpine mono powering my speaker/woofer and after i changed the alternator quaility and reliability went up dramatically. the sound is alot crisper and deeper. now if your running 1200 watts (RMS im assuming) it may just be that your alternator now is old and worn out and you just need a new one. I replaced my old one with a new honda OEM one and a new battery and its totally fine now. maintains 14-14.4 volts and dosent drop below 13v even with it cranked at idle. and yes alternators are really easy to change out unless one of the bolts are rusted solid. then your fucked cut it off. happened to me
__________________ 1997 Honda Civic Si(R) Coupe EJ8
-JDM B16A SiRII swap
-DC 4-1 headers
-Skunk2 2.5" test pipe
-Skunk2 Megaflow Catback
-AEM Cold Air Intake
-Go-Autoworks B-series Radiator w/ 12" slim Fan
-Skunk2 Pro Series Full Coilovers
-Voxx Racing 17" Rims
-Yokohama Parada Spec 2 rubber
-Bisimoto Stage 2 Cams (soon to be installed)
cheap, fast, reliable. Pick Two. |
